Two issues with my Pentax SF1.
Yes, I used a brand new Duracell 2CR5 battery, good until 2022. Also, the Duracell battery seemed strong enough to allow the motor to pull the film across the guide rails. The film is loaded, however in the LCD Screen it tells me that the film is not loaded properly by displaying a flashing zero.
The second problem still exists. The mirror remains in the up position. There is no adhesive leak from the mirror damper. It seems to be in very good shape. Also, the back support for the mirror folds and unfolds just as it should.
I am thinking perhaps this is coming down to a faulty shutter issue.
Thanks for the suggestions, I do hope this will be an easy fix.
Tony
