Hi slip,
I think that Adam and Na Horuk are closest to the best answer so far. I can't read the minds of the Pentax designers, but I think it would be a pretty good guess to think that the designers included the 5 point Auto option as an expansion of the center point as an active area when shooting AF-C and moving subjects. The central AF area is relatively small (the area of the ( ) marks on the stock focusing screen), shooting moving subjects usually means using a longer lens with a subject that's relatively small in relation to the total area of the scene in the VF, and if the subject is moving, AF needs to be as fast as possible to keep up.
Reducing the AF areas that are considered active by the internal processor of the AF system from 11 to 5 will speed up the relative AF processing. Increasing the AF areas considered by a factor of 5 increases the chance of having a viable contrast border within the active AF areas, and would allow the continuous AF to stay on target if the subject is not kept perfectly centered throughout a series of exposures.
Personally, initially I did not find using 5 point mode much different from 11 point Auto Select, so haven't used it for Birds In Flight shooting, but it's a good idea on paper. Even though I primarily shoot birds, I do very little BIF shooting, and my mastery of the technique of panning accurately with a moving subject is far from the best, so I need all the help that I can get, so I stick with 11 point Auto Select to make up for my deficiencies in this area.
It's just another option that you have at your disposal if you find it useful. I'd suggest that if you shoot moving subjects with AF-C, give it a try. If you find it helpful, then use it despite what others might think of it. In the end, you're the photographer and make the choices.
Scott
