Originally posted by blackcloudbrew Don't do it
I'm afraid in agreement with blackcloudbrew on this, if you wish to go down this route, you need to serve a kind of apprenticeship of sorts.
Get yourself a job as a wedding photographers assistant, or a very closely supervised second shooter, both at this stage will probably be unpaid work. But get a good few weddings under you belt, before going it alone. This way you'll get to learn the ropes and find out what is really expected of you as the photographer on the big day.
It's not easy, it's long hours and can be pretty stressful at times, especially when your first starting out. Remember you can't just go back and do it again, so failure is not an option, you need to have back ups for all critical equipment i.e. cameras, lenses and flashes, that means at least two of each and possible three when it comes to camera bodies.
Also you need to get good insurance covering you for public liability, from being sued if it all goes wrong and your equipment being damaged or going missing.
Good luck, let us know how you get on with this.
