03-20-2013, 03:51 PM   #1
flash photos are darker than normal on my k10d
the flash photos taken on my k10d appear darker and have a bluer hue than normal.its as if the flash power has diminished.cant find anything in manual.might i have inadvertently disbled it somehow?help
03-20-2013, 04:00 PM   #2
Have you enabled exposure or flash compensation at all? This could cause the flash to fire at a lower power setting. It could also be that the flash simply isn't powerful enough for what you were shooting. Could you attach some samples with EXIF intact?
03-20-2013, 04:43 PM   #3
flash photo too dark
Hi Adam.Yes the problem seems to be that i inadvertently enabled the flash compensation.what is the default setting for this in the fn menu?.Best regards.
03-20-2013, 04:44 PM   #4
QuoteOriginally posted by celtic Quote
It should be set to 0.0. I don't remember what buttons you need to press on the K10 to change it, but on the k-5 you simply go to the flash menu and then turn the rear e-dial.
03-20-2013, 05:07 PM   #5
PEG Moderator
Kerrowdown's Avatar
It's a bugger when you've inadvertently changed a setting without realising it and we've all been there.
Hopefully that's you sorted now.
03-21-2013, 03:23 AM   #6
Hi Adam.I have reset the flash compensation to 0.0 as suggested but this appears to have had no effect.I have also attached a flashgun to the camera but still my photos appear darker than normal.The exposure compensation is also disabled.Any thoughts?.best regards,Celtic
03-21-2013, 05:01 AM   #7
bdery's Avatar
For the colours, check your white balance setting.
For the exposure, are you trying to light a room that's too large? If you're using the built-in flash, it's not very powerful. If you're using an external flash, verify where you are directing the light.
03-21-2013, 11:35 AM   #8
Not a Number's Avatar
Unless you've reprogrammed it the green button will always set exposure compensation to 0.0 (default) when you are in the EC setting modes.
There is an option to set color balance to flash whenever the flash is activated. This is another setting that can affect flash photos.
flash, flash photos, k10d, pentax help, photos
K-r darker than my Canon 300D DNT Pentax K-r 12 11-10-2012 12:46 PM
Iphone PICs are better than my K10D w/ SIgma 17-70mm vmaniqui Pentax DSLR Discussion 28 07-01-2012 08:43 PM
Help! My prints are darker than My Monitor, why Softsoap Digital Processing, Software, and Printing 27 03-11-2010 08:57 AM
My prints often are darker than intended... philbaum Digital Processing, Software, and Printing 3 02-26-2010 12:08 PM
Abstract Something Darker Than Normal Christopher M.W.T Post Your Photos! 10 10-08-2009 02:06 AM
All times are GMT -7. The time now is 06:36 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
