03-21-2013, 10:30 AM   #1
Pixels showing too much?
I am noticing an abnormally small amount of pixels (so it seeems) in certain areas of a photo in which I have taken in the DNG format.It occurs in many images. Attached is a screenshot of one example at a 100% crop. Is this normal??? If not, what can I do to prevent it? I am using the Pentax K-5 II.
03-21-2013, 10:43 AM   #2
Lowell Goudge's Avatar
What you are seeing is JPEG compression, the K5 is more aggressive than the K7 or K10 in my opinion
03-21-2013, 11:09 AM   #3
enoeske's Avatar
You are seeing a small amount of pixels because its a 100% crop. To see more pixels, don't crop the image.
03-21-2013, 11:17 AM   #4
@Lowell, how could it be a result of JPEG compression if I was shooting RAW?
@enoeske, are you saying that this is normal?
03-21-2013, 11:22 AM   #5
Not sure what you are talking about -- what am I supposed to be seeing in the example?
03-21-2013, 11:24 AM   #6
enoeske's Avatar
QuoteOriginally posted by noahdsnell Quote
I'm saying that you don't know what a pixel is.
03-21-2013, 11:25 AM   #7
@vonBaloney, the pixels showing significantly in the turtle's eye. I am not sure whether or not it is normal.
03-21-2013, 11:30 AM - 1 Like   #8
@enoeske, I know what a pixel is. I know there are less pixels in the frame at the 100% crop. I am just saying that I do not normally notice pixels blending like they are in the turtle's eye. I am not sure whether or not it is normal, or if there is something I can do to fix it.
03-21-2013, 11:38 AM   #9
Ok, blockiness there, gotcha. So if this was shot in raw and converted to tif "losslessly" then you're right, you should not be showing those artifacts (from that). If that is true, that can't possibly be a 100% crop because a 100% crop means a pixel in the image is exactly one pixel on the monitor. But it looks more like compression artifacts -- who converted/how did it become a tif? Picasa?
03-21-2013, 11:44 AM   #10
Senior Moderator
Parallax's Avatar
QuoteOriginally posted by enoeske Quote
Or perhaps you don't know what he's asking?
03-21-2013, 11:47 AM   #11
@vonBaloney, I converted it with FastStone, but the same effect is showing up on the original RAW file (along with some others)
03-21-2013, 11:52 AM   #12
jatrax's Avatar
What are using to view the RAW? Some viewers only show the jpeg thumbnail not the actual RAW conversion. That really looks like it is the thumbnail blown up to 1:1 not the actual RAW.
Try the same shot shooting jpeg and see if the issue is still there.
What are you using to process your RAW files? Lightroom? Aperture?
03-21-2013, 11:54 AM   #13
Not possible in the original RAW at 100%, so your viewers and converters are not showing you the right thing. In absence of Lightroom or other (that works right), do you have the Pentax software?
03-21-2013, 11:59 AM   #14
I am just using FastStone for a quick edit. I do not have a copy of Photoshop on my laptop yet unfortunately. I would try to shoot jpeg, but not all images are coming up like this. So I would need to find a situation in which I can tell from the camera that it is having this issue. But I think you are right, I am probably viewing a 100% crop of an enlarged thumbnail. Do you have any suggestions for a good RAW photo viewer?
03-21-2013, 12:06 PM   #15
I quickly installed a trial version of Photoshop Elements for this specific purpose, and it looks as if the image is coming out much, much better on there. I guess FastStone was just showing a 100% crop of the thumbnail, and converting incorrectly. Such a good program otherwise. Thanks for your help. Does anyone know a good RAW photo viewer (not editor) that works as it should?
pentax help, pixels
How much focus correction is too much? Tanzer Pentax SLR Lens Discussion 4 10-18-2012 09:30 PM
How much BF/FF adjustment is too much? JinDesu Troubleshooting and Beginner Help 19 07-11-2012 03:06 AM
Too little, too much black and contrast. lbenac Film Processing, Scanning, and Darkroom 7 11-23-2010 09:52 PM
When is too much, too much? lbenac Film SLRs and Compact Film Cameras 15 05-03-2009 04:49 PM
PP: How much is TOO much? mikeSF Digital Processing, Software, and Printing 40 02-06-2009 11:30 AM
All times are GMT -7. The time now is 10:11 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
