Originally posted by MADDSNIPER why wasnt it working before though? im manually turning the aperture ring with my hand...surely that should adjust the aperture in any mode just like turning the focus ring does. I didnt think the camera would have the ability to edit the aperture itself anymore than it can edit the focus on a manual focus lens, but in the 2 photos i posted they both had the same aperture setting when i clicked to take the shot?
The basic K-mount design used on your M series lens has two ways to move the aperture blades. When the lens is off the camera you can see them both; turning the aperture ring or moving the lever both move the blades. The other feature of the K-mount holds the blades wide open for focusing and metering, only closing the blades when the shutter opens. The camera can tell if you have set the aperture ring to f8 and uses that information for metering. The original K-mount cameras used the aperture lever as an on-off switch: blades either fully open, or closed to whatever position the aperture ring indicated. The lever was never in-between. The lenses were designed with this on-off system in mind.
All the Pentax DSLRs use a mount that leaves out a part that would tell the camera where the aperture ring is. The part is not necessary if you are using an A series or later lens, because the camera doesn't need the ring and you can set the aperture on the camera. Lenses with an A position on the aperture ring are designed to move the blades to fit this system, using only the lever. On these cameras, the lens is fully open for focusing. The camera knows the minimum and maximum apertures of the lens you're using, and sends that to the (more complicated) light meter and controls. When you shoot, the camera moves an actuator arm that pushes the aperture lever exactly enough to get f6.3 or f19 or whatever. (DA and FA-J series lenses don't have aperture rings because the ring and second mechanism to move the blades was almost redundant.)
When a basic M or K series lens is mounted, the camera has no aperture information at all, and no ability to move the blades as precisely as it wants to. Without that information, a lot of the clever tricks that the camera could normally do are impossible: multisegment metering, P-TTL flash, program modes, etc. are all out. Pentax does allow the camera to function in a limited way, but only in M mode. When you have enabled the aperture ring, set M mode and the camera can't detect lens information, the actuator arm works like an on-off switch. The metering switches to an old-style mode and can be set with the green button.
It sort of works, but the camera and lens are 35 years apart and sometimes not really communicating that well.
