03-23-2013, 04:02 PM   #1
almvsalutay's Avatar
K5 shutter continuing to fire.
Hi
Hope someone can help?
On my K5 as soon as I switch it on the shutter starts to fire...., In every mode, I have checked the shutter release button..its fine, no images are being saved to the SD card with this issue.
When I remove the battery and replace it, the camera functions correctly for several shots then starts automatically fire again, no error messages are shown.
Has anyone had this issue? Even when the lens is removed it still has the issue.
Regards, Al
03-23-2013, 04:38 PM   #2
GabrielFFontes's Avatar
Uh, mirror flop?
03-23-2013, 05:20 PM   #3
QuoteOriginally posted by almvsalutay Quote
Hi
Regards, Al
The infamous mirror flop syndrome.
It is a faulty main board (mother board), my K5 developed this fault (Pentax know about it). Some of the early main boards had a bung part in it.
Had mine replaced under warranty, since then everything is fine.
Greetings
03-23-2013, 05:21 PM   #4
klh
klh's Avatar
Yep, sounds like mirror flop. My K-5 is in the shop right now for that very thing.
03-23-2013, 05:41 PM   #5
The early K-5 production models had among other smaller problems two really bad problems. They were: sensor stain, where some cleaning fluid was trapped between the sensor surface and the AA filter which showed up as a string of pearls roughly across the middle of the sensor. The other was the aforementioned mirror flops.
Both were acknowledged, albeit late, by Pentax and repaired under warranty.
Greetings
03-26-2013, 03:12 PM   #6
QuoteOriginally posted by Schraubstock Quote
Greetings
Thanks everyone for the advice, I have returned my K5 to Pentax UK for repair.
Al
03-27-2013, 02:33 AM   #7
PEG Moderator
Kerrowdown's Avatar
Hope they don't keep you deprived too long.
03-27-2013, 02:35 AM   #8
Al
Hi
Just for the record it would appreciated if you could tell us the outcome when the cam is returned.
Greetings
03-31-2013, 10:46 PM   #9
RyukyuMike's Avatar
This is one, I'd like to hear the follow-up on, too. Had a similar snag with the KD10 but, never heard of the problem on a K5, 'til now.
03-31-2013, 10:48 PM   #10
twitch's Avatar
QuoteOriginally posted by RyukyuMike Quote
This is a common problem on a K5, it reached epidemic proportions in mid to late 2011, or a least it seemed that way where barely a day would go by before a new report of a flopping k5 would surface on this forum. The fix it turns out is a new mainboard.
04-01-2013, 03:56 AM   #11
klh
klh's Avatar
I got my K-5 back on Friday. Quick turnaround, and so far, no problems! Great job Pentax.
04-03-2013, 02:59 PM   #12
QuoteOriginally posted by klh Quote
Got my K5 back today, work done by Pentax UK was:
Replaced diaphragm, AF motor and connection FPC- upgraded firmware-check and test.
Everythings working well at the minute.... a one week turnaround even over the Easter Holidays is great service.
Regards, Al
issue, k5, k5 shutter, pentax help, shutter
k5 doesn't fire when focussed. London Rob Troubleshooting and Beginner Help 15 02-22-2013 06:57 PM
Constant shutter fire. Pontax Pentax K-5 & K-5 II 6 07-29-2012 05:25 AM
mz-7 shutter won't fire jefflichty Pentax Film SLR Discussion 2 12-28-2009 05:12 AM
Help!! 67 Shutter won't fire. Swift1 Pentax Medium Format 5 10-05-2009 01:05 PM
All times are GMT -7. The time now is 04:06 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
