Originally posted by Jenni0482 Hello all!
This is my first post and I am just wondering if anyone else has trouble shooting decent shots with their K10D in low light. Even on auto, with the flash the photos are dark and color off? I borrowed a Canon Rebel XSI from a friend and the difference in low light is night and day! Is this a problem with the model in general, the stock lenses (18-55mm, 50-200mm), or something really obvious that I am missing? When I compare stats for an auto indoor shot with flash, the Pentax chooses the highest possible ISo 1600 while the Canon is shooting at 400.. What gives?
I am not a super newbie, have been shooting for 15+ years with both manual film SLR's and have had the Pentax for 5-6 years. I still have a lot to learn, but shooting indoors shouldn't be this hard..
One thing to note is that in auto mode, with flash Pentax programs the camera to do a couple of things. First of all, it will attempt to meet the exposure requirements without flash. This results in shutter speed going to the hand held minimum of 1/FL sin with flash shake reduction is off, and also bumping ISO up to maximum,and aperture wide open, so that the flash is only fill. Rule number 1 never use flash in full auto. Take control of the camera, don't they it take control of you.
Second thing is that on board flash is not all that powerful, GN 13(I think) this means 13 meters at F1 and ISO 100, so it does not have a lot of reach.
Lastly you need to look at the metering mode, you need to decide if you want whole scene illumination, or just the subject, so select either matrix metering or spot to get what you want. Note with spot metering, the background will fall off to black, since light falls off at the square of the distance.
