04-01-2013, 07:46 AM   #16
crewl1's Avatar
Thank you all for your most attentive and helpful responses.
Here's wishing you a wonderful April 1.
04-01-2013, 07:59 AM - 1 Like   #17
Anvh's Avatar
QuoteOriginally posted by Tom S. Quote
Maybe you should put it in the microwave to dry it out?
I don't believe there is a warning for that inside the manual
04-01-2013, 08:53 AM   #18
JinDesu's Avatar
Humorously, there is another user who actually did what you wrote - you have to check out the sports photography thread. He stuck it in, snapped, pulled out, dried, and no problems whatsoever
https://www.pentaxforums.com/forums/pentax-k-5/115277-k-5-sports-photography-50.html#post1961670
https://www.pentaxforums.com/forums/pentax-k-5/115277-k-5-sports-photography-50.html#post1961942
04-01-2013, 10:23 AM - 1 Like   #19
Blue's Avatar
QuoteOriginally posted by macTak Quote
The problem here was not the water, but the chlorine (and probably urine; the Olympic champions admit that they pee in the pool) in the water. Pentax advertises resistance only to water, not to a chlorine/urine cocktail, and these chemical deposits have damaged the camera. To remove them, you need to thoroughly clean the camera with regular water. Take the lens off and run all parts of the lens under the tap (make sure to zoom and focus the lens aggressively whilst under the tap to break up any deposits!); then do the same for the camera (make sure you the mirror box is washed out well too, as deposits could be lurking there!). If the camera still doesn't work, the deposits have obviously adhered beyond the point of solubility, and you will have to shift them. To do this, use a hammer to strike all portions of the camera and lens. If somehow this fails, then you will have to buy a new hammer.
Maybe they should just designate a "peeing section" in the pool.
04-01-2013, 01:22 PM - 1 Like   #20
VisualDarkness's Avatar
Did you mount the lens the right way? The contacts should face the camera mount and the filter end should face outwards. It's pretty easy to do wrong.
04-01-2013, 02:48 PM   #21
Moderator PEG Judges
Kerrowdown's Avatar
QuoteOriginally posted by crewl1 Quote
Pentax K-5 Water proofing - false advertising
Thanks for your posting, it raised a wry grin with me.
04-01-2013, 04:29 PM   #22
Don't be silly. You should not put a camera in a microwave oven.
Use a convential oven at 350 degrees for 45 minutes. Don't forget to pre heat it.
This is a joke. Don't put a camera in the oven. Serious responses will resume on Tuesday, April second.
04-01-2013, 04:45 PM   #23
p38arover's Avatar
QuoteOriginally posted by lmd91343 Quote
It's been the 2nd April for nearly 11 hours (here) so I'm gunna be confused what is tongue in cheek and what is real info!
04-01-2013, 07:29 PM   #24
patrick9's Avatar
QuoteOriginally posted by p38arover Quote
That's OK I live confused
04-01-2013, 08:19 PM   #25
Good luck to you!
camera, k-5, pentax help, pool, power, shot, shots, warranty, water, wr
Pentax K-x False message "No card in camera" wedwardes Troubleshooting and Beginner Help 16 01-29-2013 09:50 AM
My K-5 water test kshapero Pentax K-5 8 06-12-2011 05:58 PM
K-5 Advertising, better late than never. the swede Pentax News and Rumors 19 10-09-2010 06:32 AM
K-5 rumors false! Adam Pentax News and Rumors 260 09-16-2010 06:18 PM
Broadway Photo False Advertising AF540FGZ StevenLS Flashes, Lighting, and Studio 19 07-24-2008 08:02 AM
All times are GMT -7. The time now is 08:20 PM. | See also: NikonForums.com, part of our network of photo forums!
