Originally posted by barkii Thanks to all of you who commented. I know a little more about the subject now. Imagine, if the gas level indicator in a car would work the same way.. You leave home believing the tank is full, and 10 minutes later, on the highway, its empty....
The K10D especially worked this way, it showed full until it was almost dead. As soon as it moved, you had about 10 shots left.
The K7 and K5 are significantly better in this regard, but, if you have a high usage function, live view, or continual checking of your shots, it will seem to go down pretty fast. I think the K7 and onwards use the third terminal to get a bett estimate of battery life, the K10 battery only has 2 terminals, so all the indicator can look at is the terminal voltage, not any internal points of the battery
