Hi all,
I have just taken proud ownership of an... i dunno what! A cheap Ebay special, so im not overly concerned I have screwed up and bought something thats of no use to me!
I though it was merely going to be a PK macro extension tube (approx 40mm - 1 3/4") , however, while one end does indeed fit my K-r, the other is a similar bayonet design but of larger diameter with a locating pin/slot in one of the blade sections.
Now I have hunted around google and here looking for what it could possibly be, and looking at rick_olesons list of images, the closest Ive come to it is the minolta type, with the notch in one of the blades, however this one has the cut out in the female part of the assemby? I assume again, to take the locking pin of whichever size lens it is.
Its markings are BA , Germany Penta. Thats it! I couldnt find any reference to the BA bit during my historical search!
Pictures below may help.
Two parts - the smaller ring (with label 'penta') is a double sided male and male blade , PK one side - fits the k-r, and the other side a smaller diameter version with a pin cut out on one blade- which fts correctly into the second main body of the adaptor (label germany BA)
Then at the other, and (I assume) lens end, is the larger than PK, 3 blade female socket with the pin cut out . (if PK main lens diameter, not including the width of the blades, is about 45mm, this one is 50mm.
And if that weren't enough, theres even an internal thread each end as well which i think may be M42!
Thoughts ladies and gentlemen please!
**EDIT** As soon as I posted this I had a senior moment brainwave! - Bellows Adaptor!!
So now Im thinking along those lines!
Reason: more thoughts
