04-05-2013, 04:25 PM   #1
Gallopingphotog's Avatar
When is it time for a new battery?
I bought my k10D with two batteries from my cousin. She said she hadn't used it much, and it is in pristine condition, but I don't know what she meant by "not a lot." And I have no count of the number of times I've recharged these batteries.
So, how will I know when either/both of the D-LI50 batteries will be near the end of their lives? Will it run down faster and faster? Take longer to recharge? On our travels we sometimes are past the back gate to nowhere and I'd hate to be there when one or both batteries decide to throw in the towel permanently!
04-05-2013, 05:16 PM   #2
hcc
hcc's Avatar
At end of life, a battery can only provide less and less shots. Recharge time is alway about the same usually.
You shoudk test both batteries. The best way is possibly to fully charge each battery, and to use it. If you can get only 100-200 shots, the battery is near its end of life. (Better to throw away IMO.) If you can get more than 400 shots or more (before recharge), go for it. I like to have always two fully-charged batteries with me (in case), and I tend to use one, then the other to share the load.
Importantly, do fully-charge each battery (not half-way); it may take a couple of jours, possibly more, but do it.
Hope that the comment will help
04-05-2013, 10:01 PM   #3
Very helpful
Thank you. Both batteries seem to be doing quite well and it sounds like I'll get plenty of warning, time enough to get a new one.
04-06-2013, 05:53 AM   #4
Moderator PEG Judges
Kerrowdown's Avatar
I also tend to replace mine fairly often on a first in, first out basis, probably more often than I actually need too. I treat these as the cheap bit of photography and are therefore consumables.
But for me failure is not an option and that's why I also carry a few spares at any one time, belt and braces that's me
04-07-2013, 12:45 PM   #5
reeftool's Avatar
I usually replace a battery when it no longer holds a decent charge. My K10D battery is still going strong after 6 years.
04-07-2013, 03:47 PM   #6
DSLRs are pretty close to a perfect use-case for Li-Ion batteries like the D-Li90. Lithium Ion batters actually last longer when charged starting from a higher charge, and if you can use less voltage charging. Even shooting 300 or 400 pictures in a set, I rarely drain my K-7 or K-5 below half battery.
Source: How to Prolong Lithium-based Batteries - Battery University , lots of numbers and fluff
batteries, camera, pentax help, photography
Landscape When it is foggy, it's time for photograph... LFLee Post Your Photos! 9 01-17-2013 10:18 AM
Is it time for a new U.S. Constitution? luftfluss General Talk 57 07-30-2012 11:55 AM
It's time for a new tripod, help vievetrick Pentax Camera and Field Accessories 27 01-04-2012 08:23 PM
When is a good time to use a manual only lens? Vantage-Point Pentax SLR Lens Discussion 31 05-12-2011 07:52 AM
It is time for a bag...can you suggest something for me? timstone Pentax Camera and Field Accessories 23 04-14-2010 11:40 AM
All times are GMT -7. The time now is 11:35 PM. | See also: NikonForums.com, part of our network of photo forums!
