04-11-2013, 04:08 PM   #1
quick-shift?
I have a K2000 Pentax camera. Will the quick-shift in the DA 55-300mm Pentax lens work? Or if it doesn't work then will I be better off buying the DA L version? I'm not sure what the quick-shift does or how necessary it is to a novice user.
Thanks,
Trey
04-11-2013, 04:31 PM   #2
jatrax's Avatar
Quick shift allows you to focus manually while the camera and lens are in auto focus mode. It is very useful for a lot of things. Often the camera will focus on a branch or something close to where the bird you want to shoot is, with quick shift you can manually tweak things just the way you want.
No reason it should not work on your camera it is inherent to the lens design and has nothing to do with the camera.
I have the DA L version and it is fine but if given the choice I would take the DA version with quick shift. You also get a hood and a metal mount with the DA version.
04-11-2013, 04:36 PM   #3
Thanks this was just what I wanted.
Trey
04-11-2013, 08:47 PM   #4
Banned
Just remember to let the camera finish focusing before you use the quick shift, you also need to keep the shutter button half pressed or you'll start the whole process over again.
04-12-2013, 08:35 AM   #5
JimJohnson's Avatar
I too would love to have the Quick Shift (DA) versions of my DA L lenses. That said, I've become fairly proficient at flipping the switch on my K-r from AF to MF, doing my manual focus tweak, taking the shot, and flipping the switch back to AF. Still nowhere as convenient or fast as Quick Shift however. But if like me, you find a sweet deal on a DA L version of a desired lens, you put up with the inconvenience.
04-12-2013, 08:47 AM   #6
dboeren's Avatar
I held strong until I found a sweet deal on a DA 55-300, quick-shift rocks and since I would be using this lens for wildlife shots being able to correct the focus onto the animal instead of the branch is something I expect to use quite a bit.
04-12-2013, 07:25 PM   #7
Kozlok's Avatar
One thing you can do with a non-quickshift lens is press the lens release button with your pinky, and change focus. The torque required to remove the lens is much higher than required to focus, so it won't come off doing that (unless you yank it around!). Voila, all lenses are now quickshift!
04-13-2013, 03:43 PM   #8
Na Horuk's Avatar
QuoteOriginally posted by Kozlok Quote
Hm, good point, but isn't that basically as much work as moving the AF/MF switch?
04-13-2013, 04:44 PM   #9
JimJohnson's Avatar
I tend to move the AF/MF switch, but Kozlak's technique may be faster because you have to move the AF/MF switch back to AF yourself, whereas the lens release button will pop back on its own.
The risk is if the lens rotates at all in the mount - either direction, you will lose not only AF but also aperture control from the body - - that's especially not nice on a lens that doesn't have an aperture ring.
04-14-2013, 11:07 AM   #10
Kozlok's Avatar
The lens won't rotate. The mount is much tighter than the focus ring. Heck, my M42 lenses are all on fotodiox adapters with the clip removed, so they are free, and my Helios focuses much harder than any other lens, and it doesn't budge in the mount.
My technique is also easier because at least on my K-X, the A/M switch is very hard to slide, and it takes the left hand and a bit of concentration.
04-15-2013, 06:27 PM   #11
ramseybuckeye's Avatar
QuoteOriginally posted by Trey Vincent Quote
Thanks,
Trey
I have the DA 55-300 and do a lot of wildlife/birds and the quickshift is great. The lens has a noisy focus with a long throw. I can focus faster and quietly using quickshift. It pretty much is necessary, because that noisy autofocus will scare a bird or chipmunk away every time.
camera, da, pentax, pentax help, photography, quick-shift
DA 50mm F1.8 Quick Shift? Adam Pentax SLR Lens Discussion 5 08-22-2012 11:42 AM
Quick Shift CMG Pentax SLR Lens Discussion 5 08-16-2012 07:58 PM
What is Quick Shift Focus System? zhang8865 Pentax K-r 19 07-12-2012 02:57 PM
Quick-shifting FA without quick-shift hjb981 Pentax SLR Lens Discussion 41 06-01-2011 07:28 PM
Permanent quick-shift? LeDave Pentax DSLR Discussion 12 12-27-2009 12:41 PM
All times are GMT -7. The time now is 09:31 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
