04-18-2013, 08:07 AM   #16
what if i unscrew the mounting bracket from the camera and try a loose fit onto the body adapter that way i can see whats going on
04-18-2013, 09:51 AM   #17
Not a Number's Avatar
That's a good idea.
04-18-2013, 10:31 AM   #18
MSL
MSL's Avatar
That's a good idea.
No its not, and the original poster may not recognize you are being sarcastic.
As many have said, you need to post a photo of the end of the tube and we should be able to tell pretty quickly whether it will work or not. Which lens are you trying to use these tubes with and which camera?
I have a similar set of tubes, and I don't use them much anymore except as a full set. I found that every time I unscrewed them to change the length bits of black paint would fleck off with the risk of ending up in the camera. I have to agree with @SOldBear that you need to put a lot more detail into your posts if you want useful replies that will solve the problem.
04-18-2013, 11:24 AM   #19
bluestringer's Avatar
QuoteOriginally posted by Arimel Quote
If you're talking about removing the mount from the camera, no not a good idea. Does your male end of the tubes look like these pictures. This is the section that mounts to the camera, the rest of the pieces screw into this one, the last piece is the female end for the lens. Be sure to line the red dot with the mount dot on the camera.
04-18-2013, 01:15 PM   #20
it took me several times and an hour heres the pictures. im running off a 5 gig wifi signal
macro, pentax help, tubes
Macro extention tubes R Jude Visitors' Center 6 07-06-2012 12:22 PM
VL Nokton 58 f/1.4 with extention tubes??? OrenMc Pentax SLR Lens Discussion 11 02-11-2011 03:35 PM
For Sale - Sold: PENTAX PK Extention Tubes (Worldwide) JeffJS Sold Items 2 03-13-2010 08:15 PM
Rear converter and Extention Tubes robertdyne Troubleshooting and Beginner Help 2 04-06-2009 08:28 AM
Questions: using extention tubes? OrenMc Pentax Camera and Field Accessories 4 03-04-2009 05:35 PM
All times are GMT -7. The time now is 09:53 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
