04-19-2013, 02:52 PM   #1
Removing a stuck lens from a K-01
Hello All,
Can someone help me? How do you remove a stuck lens (Sears 135 mm f/2.8 Macro) without damaging the lens mount or the lens?
04-19-2013, 02:58 PM   #2
jatrax's Avatar
Do a search for "ricoh pin stuck lens". You will find many threads and lots of tricks to get it off.
Most important thing is: you CAN get it off, take a deep breath and study the threads so you don't damage the camera or lens.
04-19-2013, 02:58 PM   #3
QuoteOriginally posted by V'cuz Quote
Hello All,
Regular K-mount lens? Might have a Ricoh pin. First thing to try is to set AF-MF switch on body to MF -- this will retract the AF screw drive. Actually, try it both ways (and try it with camera turned on and AF switch turned on). But only apply *light* pressure -- don't force it.
04-20-2013, 12:54 AM   #4
Moderator PEG Judges
Kerrowdown's Avatar
There's lots of information on this Ricoh pin issue on the forum, take your time, don't panic it can be done, good luck.
Lets us all know how you get on.
lens, pentax help
K-01 and a Pentax 645 A-type manual focus lens -- need advice jon404 Pentax K-01 2 02-21-2013 09:12 PM
Removing Stains from K-01 uhuglueee Pentax K-01 11 04-08-2012 10:41 AM
a few quick (i hope) questions on the K-01 from a Pentax and DSLR newb krugorg Pentax K-01 7 03-13-2012 06:22 AM
Question of focus with a manual lens on a K-01 visual zen Pentax K-01 3 02-18-2012 10:27 AM
Removing a Takumar Lens Faceplate Help MobiusOne Pentax SLR Lens Discussion 7 11-07-2011 07:26 PM
All times are GMT -7. The time now is 10:56 AM. | See also: NikonForums.com, part of our network of photo forums!
