04-20-2013, 05:55 PM   #1
K200D misbehaving built-in flash
Hello everybody,
Just received a K200d today in the mail and popped in some new batteries to test it out before I left the seller feedback. Straight away this is some of the behavior I was experiencing.
I was set in portrait mode, all auto settings. I was testing the auto focus with the shutter button partially depressed. The auto focus started to kick in, but at the same time the built in flash popped up which is normal I'd say. The next part isn't. After the flash popped up and the shutter button still partially depressed, the flash started to intermittently 'flash' with a sort of electrical zapping sound on and off repeatedly for a few seconds. I released the button and then pressed it again. happened a second time. This all occurred without the shutter ever actuating. After more trial, the issue never presented itself again, and the flash worked perfectly as you would expect.
After my initial trials I wanted to see if i could make it happen again. I can.
Is this some type of feature that allows the camera to adjust the amount of flash/light needed for the photo prior to shutter actuation? Or is this a malfunction?
Any help or insight into this 'issue' is much appreciated to a newcomer on this helpful forum. (I'm new to dslrs aside from some classes back in high school).
Thanks!
04-20-2013, 06:57 PM   #2
That was the Paranormal Activity Detector, were you near a Graveyard ?
Really, just the autofocus pre-flash if there is not a lot of light. Supposed to help against Red Eye.( And temporarily blinds Zombies so you can get away )
You can turn it off in the menus.
If you don't have one, Download the manual from Pentax . Lots of settings to learn.
04-20-2013, 07:15 PM   #3
Just1MoreDave's Avatar
Definitely download the manual. See if this link works:
Downloads & Literature - PENTAX Imaging USA
If it doesn't, Digital Cameras by PENTAX - Waterproof Digital Camera - Digital SLR, then Support (upper right), then Downloads on the left, then Digital SLR, then K200D, manuals is at the bottom. There's also a firmware upgrade for better stability with SDHC cards, kind of optional.
I think if you press the Fn button, then the down arrow, then choose the lightning bolt without anything else around it (second to the left), that's manually controlled flash. I think that disables the flash firing to make AF work better, unless you manually raise the flash first. It should only happen in low light anyway.
04-20-2013, 07:22 PM   #4
QuoteOriginally posted by bobpur Quote
Hahaha, good one. I was hoping it was some type of feature and not an equipment malfunction, I will try to turn it off and see what happens. I was downloading the manual as I typed the original post and just started to read it actually. Thanks for the help!
QuoteOriginally posted by Just1MoreDave Quote
Done and done, thanks!
04-20-2013, 10:39 PM   #5
sterretje's Avatar
QuoteOriginally posted by SlyClockWerkz Quote
If you did those tests in proper daylight, I'm not sure if it's supposed to happen. Else, to my knowledge, it's a feature when you use the special modes. When the camera has problems focusing, it will pop up the flash for AF assist. You can prevent this by using normal modes like Av, Tv and M (and possibly P).
auto, button, flash, focus, k200d, pentax help, shutter, time
Using Built in Flash in Wireless mode with External Flash i.e AF-360fgz disco_owner Flashes, Lighting, and Studio 7 05-16-2012 07:41 AM
k200d built in flash dimid Troubleshooting and Beginner Help 7 10-13-2009 09:04 PM
K200D: using built-in flash to trigger optical slave? cheekygeek Pentax DSLR Discussion 5 07-01-2009 09:13 PM
K200D ISO when using built in flash? BobG Pentax DSLR Discussion 7 03-09-2009 01:10 PM
wireless flash using built in flash k200d dtra Flashes, Lighting, and Studio 3 04-04-2008 12:34 AM
All times are GMT -7. The time now is 03:24 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
