Originally posted by layfsphoto I checked it for dirt. And nothing . The slide goes back into lock position and out of the locked postition. Still the lens does not zoom out. It feel like was ever engages that slide lock has broken inside the barrel. Is there a way to disengage that piece or remove the lock ? Does it pop out? I have been trying to find a diagram of the lock system to see if it is possible to remove the lock altogether with out taking the lens apart. Any ideas i would listen to Thanks
BL>
Hi! I had great success in releasing the lock on this 19-250mm Pentax lens. now if i can find out where I found the solution! I had done a search on Google answer (and they supposedly have tech contacts that can give you an answer) but their “Professional” said take it to a camera shop for dismantle and repair!
DON’T DI IT! There is a simple answer.
Have you done a search on pentaxforums.com ? There is an answer which I am going to search and let you know, if/when I find it. ! can’t remember exactly but it was loosening a simple screw to release it.
i just email the contact who gave me his solution and asked him to send me the link to his results and forward it.
TommyRingo
---------- Post added 03-25-19 at 10:56 AM ----------
Originally posted by layfsphoto My Pentax Lens the 18-250 zoom lock button is jammed in the lock position.
I need help fixing this problem . I cant currently afford to fix the lenes at the local repair shop much less sending it to the Pentax repair center. Anybody with Ideas i will give them a go.
Link: Fixing the Stuck/Jammed Zoom on a Pentax/Tamron 18-250 Lens at:
How to Restore Chrome Browser After Encountering "Bad Request-Request Too Long" Error on SharePoint Server
