Show Printable Version 7 Likes Search this Thread
04-22-2013, 01:04 PM   #1
Pentax Lens 18-250 Smc. Lock button jamed
My Pentax Lens the 18-250 zoom lock button is jammed in the lock position.
I need help fixing this problem . I cant currently afford to fix the lenes at the local repair shop much less sending it to the Pentax repair center. Anybody with Ideas i will give them a go.
04-22-2013, 02:30 PM   #2
hcc
hcc's Avatar
I have a DA8-250mm and never read about this issue in this forum. Can you post some photo of the lens and lock? Is it simply dirt inside the groove that could be scrubbed out?
05-03-2013, 07:47 AM   #3
Slide lock.
I checked it for dirt. And nothing . The slide goes back into lock position and out of the locked postition. Still the lens does not zoom out. It feel like was ever engages that slide lock has broken inside the barrel. Is there a way to disengage that piece or remove the lock ? Does it pop out? I have been trying to find a diagram of the lock system to see if it is possible to remove the lock altogether with out taking the lens apart. Any ideas i would listen to Thanks
BL>
05-03-2013, 10:07 AM   #4
tomwil's Avatar
This problem has been mentioned before, here and here, with no solution offered other than repair.
One possible solution, if the lens is out of warranty and involves unwanted repair costs, is to break the cheap lock. Apparently this is done by physically twisting the zoom while locked, as explained in one of the ratings posts here:
My only complaint was the zoom-lock switch, it felt flimsy and a constant irritation. My daughter, who is a photographer of many years, turned the zoom when the switch was locked and the switch popped off the lens and was lost. My complaint is this; if it is a ZOOM-LOCK SWITCH make it LOCK THE ZOOM!! Make it strong enough that my dainty daughter can't break it when using the zoom.
Tamron advises against this action here:
Zoom lock switch cannot be activated unless the lens is set to the shortest position. Do not
force the lock switch or try to rotate the zooming ring while locked; doing so may damage the lens.
05-03-2013, 10:23 AM   #5
Slide lock.
I attached the picture of the lock. Does it pop off with flat head screw driver. As said above torquing it off will not work but to break the lens. If i could afford to sent it in for repair i would but its a bit tight in the funds department. I was looking for a cheap fix. Thanks as always.
05-07-2013, 10:42 AM   #6
QuoteOriginally posted by layfsphoto Quote
i STILL HAVE NOT SEEN ANY BREAKDOWN ON THE PARTS FOR THIS LENS. IF ANYONE HAS THEM IT WOULD BE NICE.
THANKS
05-08-2013, 07:09 AM   #7
tomwil's Avatar
From here:
I also asked them to send the parts diagram to assist in the repair process. In fact Tamron will fax you a parts diagram for any lens they sell.
05-14-2013, 11:03 AM   #8
Ok i emailed Pentax. See what I get. I really enjoy that lens.
05-21-2013, 01:23 PM   #9
Denied, of course they want me to pay to get it worked on. That sucks.
05-21-2013, 02:20 PM - 1 Like   #10
K(s)evin's Avatar
Contact Tamron and get a parts diagram for their version of the 18-250. Same lens, differently badged.
Any more yelling and you will be sent to your room!
05-21-2013, 03:19 PM - 1 Like   #11
crewl1's Avatar
The attached diagram I received for a previous repair may not be detailed enough for what you are trying to do but it may provide some guidance.
I suggest to follow dis assembly procedure similar to this one DIY Tamron 11-18mm Lens Repair | Things I'm doing
And you may also reference images from this ebay posting Broken Tamron Di II AF18 250mm F 3 5 6 3 LD Aspherical If Macro 4 Canon as Is 0025211187210 | eBay
05-24-2013, 11:13 AM   #12
Oh i see. I didn't realize it was the same my bad.. And thanks crew for the link I think i will be able to get started on this soon.
05-08-2018, 03:50 PM - 5 Likes   #13
I've just encountered this problem in May of 2018, discovered its cause, and created a web page detailing the simple repair (which can be accomplished with a modicum of skills in a matter of minutes). Hope this helps someone:
Fixing the Stuck/Jammed Zoom on a Pentax/Tamron 18-250 Lens
Regards,
Ellsworth
06-05-2018, 11:22 AM   #14
Thanks @Ellsworth - I had the same problem this weekend - In the hindsight, yes the lens was randomly locking/feeling hard to zoom every now and then lately, so that is encouraging given the symptoms you described! I will give your fix suggestion a shot tonight - you said the lens broke during airshow? I might be carrying my K-500 and the Tamron lens in the same airshow at CHS-AFB then! Will keep you posted with my updates on the fix :-)
06-06-2018, 05:28 AM   #15
YOU ARE THE MAN @ELLSWORTH! Took me 5 minutes to fix the lens. Only had to move the rubber grip partially to expose the screw, tightened it up and BAM, back in business! (unfortunately I was so excited, I then left my K-500 on a top shelf and it dropped by itself to have a cracked screen protector plastic - no major damage and camera works fine, i just have to make sure the screen doesn't touch any water - bummer!)
answer, button, camera, ideas, lens, lock, pentax, pentax help, pentax lens, photography, position, repair, search, shop, troubleshooting
Pentax 18-250 DA WR lens solomoj13 Pentax SLR Lens Discussion 7 07-24-2012 06:08 PM
For Sale - Sold: SMC Pentax DA 18-250 f3.5-6.3 ED AL(IF) tas 0425 Sold Items 3 03-12-2012 05:26 AM
New Sigma 18-250 Vs Used Tamron/Pentax 18-250 regardless of the price ishchupak Pentax K-5 & K-5 II 11 09-26-2011 01:45 AM
Pentax SMC DA 18-250 vs Sigma 18-200 DC - Which One Should I Buy? Macca35 Pentax SLR Lens Discussion 3 04-14-2009 07:33 AM
New Pentax SMC 18-250 problem mito Pentax SLR Lens Discussion 13 01-22-2008 12:41 AM
All times are GMT -7. The time now is 02:27 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
