04-30-2013, 03:36 AM   #1
horizontal lines in Q image with adapter lens?
hey guys.
very new to DSLR.
i have bought pentax q and an adapter so i can fit my canon efs 18-55m on pentax q.
as you can see one is taken without any lens from my pentax q and the one with said "youberry" is the one with my canon lens.
how come there are horizontal lines across my pics?
is this because perhaps i use bad adapter and canon lens on my pentax q?
cheers guys
04-30-2013, 03:37 AM   #2
bte first pic is meant to be the one with youberry one but i cropped it...thanks! second one is without lens
04-30-2013, 03:48 AM   #3
That...doesn't look normal at all. Looks like a sensor flaw, but a thousand times worse than any flaw I've ever seen. Did you perhaps place your camera into a paint shaker?
Essentially - I'd contact the seller of the camera, and request a refund. That's a horrendous flaw.
04-30-2013, 03:55 AM   #4
well as you can see 2nd pics are done with no lens on the body.
1st one is canon efs 18-55m
is this can be happen due to using different company's lens with (made in china adapter?)
04-30-2013, 05:26 AM   #5
calsan's Avatar
without ANY lens??? eh? how did you get any image at all?
04-30-2013, 06:07 AM - 1 Like   #6
VisualDarkness's Avatar
It's interference between the sweeping read of the sensor and flicker from the artificial lighting. Our eyes get tricked that the lighting is constant but in reality it's just pulsating. Nothing wrong with the camera as this is how an electronic shutter works under some artificial lighting, and the only thing you can do is try different shutter speeds or change the lighting.
04-30-2013, 06:17 AM   #7
QuoteOriginally posted by calsan Quote
You can shoot without a lens but it will just be some odd purplish mess.
04-30-2013, 06:38 AM   #8
that is soooo relief....thank you god
04-30-2013, 06:51 AM   #9
Try it outside and you'll see if there's a problem.
04-30-2013, 07:08 AM   #10
I quite like the first shot. It looks like you're spying through someone's blinds.
adapter, canon, guys, lens, lines, pentax, pentax help
pentax q video with 06 lens, pk adapter with da200mm and da300mm pearsaab Pentax Q 10 03-07-2013 11:18 AM
Rounded lines in image sonic_flower Pentax K-5 5 01-07-2013 06:17 AM
Horizontal lines in long exposure?? privateryan Troubleshooting and Beginner Help 4 05-29-2012 10:59 AM
k-7: dark horizontal lines live view? bad sensor? zosxavius Pentax DSLR Discussion 2 05-26-2012 10:18 PM
Thin lines in scanned image SirDrinkalot Film Processing, Scanning, and Darkroom 4 11-20-2011 04:31 PM
All times are GMT -7. The time now is 01:45 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
