05-01-2013, 04:18 PM   #1
Focusing trouble with pentax DA 60-250
Hello,
I have a Pentax DA- 60-250mm and a K-01 camera. I purchased a Raynox DCR-250 macro snap on lens and placed it on the end of the pentax lens. It wouldn't focus right so i took it off. Now the pentax lens won't focus right. 'MF' keeps flashing on the LCD although i have both the camera and lens set to 'AF'. I try and focus on an object and it won't hold - it keeps trying to re-focus and flash 'MF'. I also can't access any menus on the camera when the lens is attached -the menu appears for a split second then the camera returns to live view. any ideas what could be the problem?
05-01-2013, 05:05 PM   #2
MarkJerling's Avatar
QuoteOriginally posted by xenocide72 Quote
Hello,
Have you tried the camera with a different Pentax lens - i.e. can you replicate the problem with a different lens?
Failing which, a reset to factory settings may be needed.
Regards,
Mark
05-01-2013, 05:08 PM   #3
Aegon's Avatar
Sometimes the AF/MF switch on the camera body can get stuck in the middle and cause weird stuff. I know you said it was on AF, but maybe give it another look.
You could also clean the contacts on the lens using a pencil eraser, rubbing lightly.
I doubt the Raynox has anything to do with the problem.
05-01-2013, 06:44 PM   #4
QuoteOriginally posted by MarkJerling Quote
Regards,
Mark
yes I have tried the camera with my sigma 17-50 lens and it works fine
05-01-2013, 06:45 PM   #5
QuoteOriginally posted by Aegon Quote
no the switch is definitely on AF on both lens and camera. I'll try the eraser on the contacts though
05-01-2013, 06:52 PM   #6
just tried the eraser thing on the contacts with no success
05-01-2013, 07:12 PM   #7
Hello,
Try the lens on another Pentax K-mount camera. If it works properly its not the lens.
If it still does not work on the first camera, try cleaning the contacts again. If all else fails send the lens in for repair.
Regards
Chris
05-02-2013, 12:10 AM   #8
wizofoz's Avatar
I can't see how a snap on macro lens could have any bearing on the AF system. My guess is that this piece of information is spurious. Do we know that the lens/camera combination was working correctly immediately before the raynox lens was attached?
You need to whittle down the variables, as others have suggested.
Good luck
05-02-2013, 08:56 AM   #9
QuoteOriginally posted by wizofoz Quote
Good luck
yeah thats the weird part. it was working the day before. no problems until i attached the snap on. could be coincidence i guess. it looks like 'm going to have to send it in for repair
05-15-2013, 12:54 PM   #10
Well just got the lens fixed. It wasn't that the contacts were dirty it was that one was actually missing! Guess I'm being a little too rough with my lens changes
05-16-2013, 03:57 AM   #11
Good to hear you got it sorted!
camera, da, focus, lens, pentax, pentax da, pentax help, trouble with pentax
DA* 60-250 owners: How do you carry your 60-250 at the ready? apisto Pentax SLR Lens Discussion 23 03-13-2013 05:42 AM
Mold problem with DA 60-250 stevemgap Troubleshooting and Beginner Help 8 03-09-2013 11:46 AM
For Sale - Sold: DA* 60-250, DA 35 Macro Ltd, DA 18-55 WR, Kenko 1.5X TC with SDM contacts buzzvic Sold Items 10 09-08-2012 07:35 PM
Landscape Another hike with the Pentax DA*60 - 250 tessfully Post Your Photos! 10 11-05-2011 07:44 AM
All times are GMT -7. The time now is 04:25 PM. | See also: NikonForums.com, part of our network of photo forums!
