05-06-2013, 07:04 PM   #1
Odd problem with my K-x
I have a Pentax K-x. I turned it on today and noticed the shutter speed box in the monitor is flashing and shows things like .6" and 1.5" or 3", not the shutter speed. Along with this the aperture box and ISO are flashing. this has never happened before.It does not matter what picture mode or lens I change to. any ideas? Did I change a setting somewhere?
05-06-2013, 07:21 PM - 1 Like   #2
carrrlangas's Avatar
short solution: Take the lens cap off!
Long one: .6", 1.5" and 3" are seconds also. Long exposures are called like that becouse well, the exposure can last from a few seconds to several minutes. Aperture and ISO indications will flash becouse your camera canīt find a combination of them that will give you a proper exposure.. Thatīs why I guesse you might have left the lens cap on.
Maybe you changed your mode on the dial. Do you use green or P mode?
05-06-2013, 07:32 PM   #3
QuoteOriginally posted by carrrlangas Quote
Ha! yes the cap was off.. I could still take picks. but I did not know that meant seconds of exposure. so that would make sense, because I was in a dimly lit room. so thanks very much. I hate it when I can't figure stuff out.
05-06-2013, 07:57 PM   #4
Glad it helped. If you use the P mode, you will be able to select a higher ISO so that the shutter speed wonīt be so low. you should try it!
box, change, k-x, pentax help, shutter
Problem with my k-x using anything but auto. Everythings tinted blue (with pics) noah240t Troubleshooting and Beginner Help 4 01-13-2013 05:12 PM
Odd white balance with K-x miltona580 Pentax DSLR Discussion 8 06-14-2012 11:33 AM
An odd problem with the k-x sensor itsmealanphan Troubleshooting and Beginner Help 3 02-17-2011 03:16 AM
Another Odd problem with my K100D photolady95 Troubleshooting and Beginner Help 3 07-12-2010 04:27 PM
possible problem with my new K-x (other than batteries) davidvcd Troubleshooting and Beginner Help 13 11-12-2009 03:43 PM
All times are GMT -7. The time now is 04:42 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
