05-07-2013, 02:41 PM   #1
kshapero's Avatar
Battery charger question
I have a Q and MX-1 and although the batteries are different, they both will fit in a Wasabi Q battery charger (not the OEM chargers). Can I charge the MX-1 battery in the Wasabi?
Specs:
MX-1 - 3.6 V - 1250 mAh - 4.5Wh
Q - 3.6V - 1000mAh - 3.4Wh
05-07-2013, 02:49 PM - 1 Like   #2
Sounds like you should be able to.
05-07-2013, 06:34 PM - 1 Like   #3
JimJohnson's Avatar
By 'fit' have you verified that contacts are in the same relative position and the same polarity? The battery case size is only part of 'fitting'. If the electric contacts are in the correct position then the worst that can happen is the MX-1 battery might not be fully charged.
battery, battery charger, charger, mx-1, pentax help, wasabi
Battery Charger Questions slackerlee Pentax Camera and Field Accessories 9 03-16-2013 11:14 AM
Ok crazy question regarding k10d battery vs. k-r battery dmbaile2 Pentax DSLR Discussion 2 08-05-2012 02:32 AM
New baby... (and a battery charger question) atekant Pentax K-5 16 02-18-2012 03:40 PM
A few questions before ordering new battery charger Jodokast96 Pentax Camera and Field Accessories 3 08-26-2011 10:30 PM
Charger compatibility question with digital concepts battery Mujibyepi Pentax DSLR Discussion 3 08-22-2009 07:46 AM
All times are GMT -7. The time now is 12:53 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
