05-09-2013, 03:44 PM   #1
Is it possible to mount flash used for Canon cameras on Pentax Cameras?
Hi, I am not sure if you guys were able to understand the question so I'll explain.
I am trying to find out whether it is possible to mount Flashes used for Canon cameras on Pentax cameras such as K-5 and still be able to use it.
Thanks!
05-09-2013, 04:24 PM   #2
Ive used a flashes meant for sigma and canon DSLRs on my k-r. They worked fine, but the ttl didnt work due to different ttl technologies. I was able to use them in manual mode though.
Do this at your own discretion as people say it can short your camera. I dont recall seeing anyone ever complain that they shorted their own camera though...
05-09-2013, 06:07 PM   #3
Class A's Avatar
QuoteOriginally posted by pcchoon Quote
Yes, as long as you are happy with manually choosing power levels (or full power all the time).
There will be no automatic exposure support since a Pentax-dedicated flash (manufactured by Pentax, Sigma, Metz, or others) is necessary for automation support.
It is entirely safe to use flashes from other brands, provided their trigger voltage doesn't exceed 30V. All recent Canon flashes stay below 6V, so are completely safe to use.
05-09-2013, 06:07 PM   #4
Bob from Aus's Avatar
Hi
Will work fine in manual mode.
Turn the flash to manual and adjust the power output. Select your settings manually on the camera.
The flash may have some auto settings as apposed to TTL settings ie set the aperture (relates to distances) on the flash - if it does that will work to just like the auto flashes did before TTL
I am assuming the canon flash is designed for digital cameras and has a low voltage that won't cook your electronics.
05-09-2013, 06:20 PM   #5
QuoteOriginally posted by subphylum Quote
Thank you
05-09-2013, 06:20 PM   #6
Thanks Very much
05-09-2013, 07:09 PM   #7
I have a mid-to-late 80's Starblitz made for Canon TTL systems. This has three pins, plus ground. It works fine in manual and auto-thyristor modes. The trigger is only about 6 volts and the two additional pins do not contact any of the auxiliary contacts on a modern Pentax hotshoe. I'm guessing a modern (brand new) Canon A-TTL or E-TTL flash should probably have one more additional pin for a digital contact, but even if that is true, I tend to doubt that it matters even if it touches other parts of the Pentax hotshoe.
Are you trying to use a new Canon flash, or an older model? If you can be more specific, you will get more direct answers.
If the flash supports auto-thyristor mode, you will be much happier than a pure manual flash.
camera, cameras, canon, canon cameras, pentax, pentax help, photography
Using Pentax DSLR with Canon FD Lenses -- Is It Possible? Tamia Pentax DSLR Discussion 27 05-12-2014 11:19 AM
Canon Clinging to Mirrors Means Opportunity for Sony Cameras RioRico Non-Pentax Cameras: Canon, Nikon, etc. 34 09-20-2011 10:08 PM
Is it possible to mount an old CCTV C mount lens to my k20d? WiseOx Pentax SLR Lens Discussion 2 07-15-2009 03:01 PM
Is it possible to use Nikon flash on K200/K2000? PentHassyKon Flashes, Lighting, and Studio 15 03-21-2009 03:49 PM
For people who understand the K mount, is it possible to make NX mount work w it? whatever7 Pentax SLR Lens Discussion 8 03-08-2009 09:53 PM
All times are GMT -7. The time now is 11:47 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
