05-11-2013, 01:19 AM   #1
Long Exposure
Hi Guys, newbie here with a K5.
I just purchased an Nuetral Density filter to get some "smooth & misty" photo's over the ocean. I read the K5 manual but couldn't see anywhere where I could set the shutter opening using the internal timer for periods of time.
I couldn't even find the section on where the timer might be or in what menu as I looked in all to no avail !
I eventually decided to set on Bulb and use menu C-3-19 set to item 1.
This was working whilst I used the iphone to time 30 or 40 or 60 secs etc, but occasionally I couldn't close the shutter again , and I noticed there was a countdown timer in the top screen !
How did I do that ?? and where did that timer come from ?? . I thought it may have been because I never had the Pentax IR , so will order a new one to try as well as a manual release , but is the same going to happen ??
Perhaps I should be setting the camera in a different mode to do this or even night shots ??
Appreciate any info you could share.
05-11-2013, 05:41 AM   #2
Countdown timer - associated with slow shutter NR. If you take a long exposure, at the end (unless the function is switched off), the camera will automatically take an identical length 'dark' frame exposure, i.e. with shutter closed, which is then 'deducted' from the original exposure in order to eliminate/reduce in-camera noise.
Using the bulb setting for long exposures you either need to (a) operate the shutter button manually, or (b) use an external plug in timer.
05-11-2013, 09:57 PM   #3
QuoteOriginally posted by JohnX Quote
Thank You JohnX , that has unravelled the mystery of what that countdown timer was doing !!!
It was also in full sun, and quite hot there so the camera internal temp may have initiated it also. Both ISO and Shutter NR's are set to Auto.
I have ordered the external plug in shutter cable release ( CS 205 ) I assume there is something similar that has a timer function set into it also ? ( not Pentax though ? ).
Would using the Bulb setting be the only way you could take this kind of shot ?
Thanks again for your speedy reply....
05-13-2013, 08:27 AM   #4
Glennat,
I also have the K5 and am a Light Painting photographer so long exposures are my life. When you go into your menu look for the setting for "slow shutter noise reduction" if you have this set to "ON" turn it off. For the times that you listed above for your exposures, you do not need this setting enabled. This could solve some of your issues. Just like JohX mentioned above, this makes your camera take two different images, since you are using a ND filter during daylight im assuming that you are shooting with a low ISO to begin with so there really is no need for this setting. You will find that once the shutter closes your image will pop right up vs having to wait for the image to process.
As for the Cable Release, I use a electronic release made by neewer. I think it cost $11 and it has the ability for me to set how long I want the shutter to remain open, as well I can place a timer before the shutter opens. When trying to shoot anything over a 30 sec exposure you need to move out of M mode and into blub mode, even if your using a cable release.
Let me know if you have any other questions.
05-13-2013, 11:13 AM   #5
Moderator PEG Judges
Kerrowdown's Avatar
Welcome to the forum, just ask a question and someone clever usually comes along with right answer, but please don't include me anywhere near the clever folk.
05-13-2013, 04:06 PM   #6
JimJohnson's Avatar
QuoteOriginally posted by kerrowdown Quote
I'll bet after a pint or three you aren't quite so humble... Serioiusly - you hold your own in this group - but I suspect everyone learns a bit here and there on this Forum.
05-13-2013, 05:37 PM   #7
QuoteOriginally posted by Sig0431 Quote
Glennat,
Thank you so much Sig0431 , that is brilliant info. That whole area in the manual is a little cloudy ! but you simplified it perfectly !
I will investigate that "neewer" cable release sounds just what I need , wonder why Pentax don't make one just like it to suit their camera's :/
I've seen a few "light Painting" shots, very interesting, facinating what images you can accomplish.
Thanks again
05-13-2013, 05:50 PM   #8
Thanks Kerrowdown, I will do.
I use to view the forums before I made my decision to purchase the camera ( all my mate's kept pushing Canon , but I wanted a Pentax ! soft spot from the film days ).
Its a great source of info, and everyone is very helpful towards each other, and as JimJohnson states I'm sure you would be a wealth of information
camera, k5, menu, pentax help, photography, shutter, time, timer
Long Exposure dtmacias Troubleshooting and Beginner Help 6 04-14-2013 10:17 PM
645D and Long Exposure delaphotography Pentax Medium Format 6 03-27-2013 08:51 AM
Low-light/long exposure mcnoco22 Troubleshooting and Beginner Help 6 05-22-2012 09:49 AM
Landscape First long exposure captainbert Post Your Photos! 2 01-14-2012 04:39 PM
How long will fresh batteries last in long exposure? tnis0612 Troubleshooting and Beginner Help 6 05-18-2010 09:11 AM
All times are GMT -7. The time now is 05:03 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
