05-11-2013, 09:28 AM   #1
ChatMechant's Avatar
K-5 suddenly stopped focusing
Was using aftermarket battery, when the camera shut off from drained battery. Put in new battery, now the k5+50-135 won't focus, just makes a noise. I can't even manual focus. The lens focuses just fine on my k-01 so I know it's not an sdm failure. Also the fact that it won't even manual focus is odd.
05-11-2013, 09:31 AM - 1 Like   #2
QuoteOriginally posted by ChatMechant Quote
Are you setting the body to MF when trying to manual focus? (That lens may not usually need it, but do it anyway.) How about a different lens? What were you doing when it shut off from the dead battery?
05-11-2013, 10:06 AM   #3
Phew! Thanks for the suggestion of using the MF switch. I set the camera to MF, and back to AFS and now the autofocus works again.
05-11-2013, 10:24 AM   #4
Probably died while focusing and got stuck in a weird mode...
05-11-2013, 11:13 AM   #5
When I had K-r the AF pin used to stuck somewhere in between AF and MF sometimes. Nothing serious, it was enough to switch from AF to MF a time or two.
But I have never had this problem with my K5IIs.
06-13-2013, 01:46 PM   #6
Driline's Avatar
The same thing JUST happened to my lens. I simply switched the camera from AF.S to MF and adjusted the manual focus on the lens to bring it back in line. Whew! SDM issue averted
battery, focus, pentax help
K-5 rear display stopped working nbu Troubleshooting and Beginner Help 10 04-07-2013 02:24 AM
Suddenly sensor overheat stopped being a problem? kcobain1992 Pentax K-01 12 01-25-2013 05:24 PM
Stopped down focusing ? Transit Pentax K-01 5 07-30-2012 03:26 PM
K-5 - Mark in photos when stopped down Codazzle Troubleshooting and Beginner Help 4 05-08-2012 08:08 PM
lens suddenly has focusing issues kjfaust Pentax SLR Lens Discussion 5 05-09-2011 01:27 PM
All times are GMT -7. The time now is 11:44 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
