Originally posted by Giklab Correction: When the built in flash is set to Controller, it wil contribute absolutly NOTHING to the exposure, since in Master it fires twice, as all PTTL flashes, but only once as Controller, to set off the slaves.
Yeah, a LOT of us wish your correction was correct, but sadly it is not. The flash in controller mode in wireless P-TTL does fire while the shutter is open, but at very low power. Don't feel bad, I used to think as you do, and Pentax's documentation can easily let you believe in this myth.
Most shots, it won't matter. And if it does matter, you will need to use one of the 3rd party options to block the visible portion of the light from the controller flash reaching the subject. I spent the US$9.95 option. It looks ugly, but I don't use it very often.
