There are 2 forms of adjustment, at least on the K20D there are, so I assume it is about the same.
You can do a global adjustment that would impact every lens that you attach to the camera.
Or, you can assign the adjustment on a per lens basis. You can do up to 20 specific assignments, and when you put that lens back on it will work accordingly.
So, if all the lenses seem off, you might try the global adjustment. If only one is off, select the adjustment so that it only affects that one lens.
Originally posted by BethC Thank you so much for that information! I will definetly do that. Okay, so if I asjust the camera for that lens, will it affect how that camera works with other lenses?
