05-14-2013, 02:02 AM   #1
40 mm XS problem
I was happy My K-01 and 40 mm f/2.8 xs.I notices 40 Xs started very poor images. not focuses good. I checked other lenses on K-01 work well. I saw 35 mm Macro and fa 31 very sharp mages on K-01. I bring 40 xs lens to service. They checked and saw problem. They opened inside of lens and they could not see mechanical problem. And finaly they say inside focus chip problem. It must be changed And it could find in Turkey
05-14-2013, 03:38 AM   #2
Ash
Community Manager
Ash's Avatar
Focus chip? I hadn't known of such a thing in the lens. You'd have to wonder such a part gets damaged with day to day use.
05-14-2013, 06:32 AM   #3
Not to much using this lens i have other lenses. Technical man opened inside lens and shows me, contacts and other parts is ok. And show me little chip. "Nec" mark on focus ring. And he say this chip may problem.
GT-I9300 cihazımdan Tapatalk 2 ile gönderildi
05-14-2013, 06:35 AM   #4
JimJohnson's Avatar
It sounds to me like the K-01's sensor is causing problems. Does the K-01 have a sensor dust removal utility? (most current bodies do) If so, I would give it a try. The sensor could be misaligned and the dust removal utility might shake it back into position. This worked for someone else in the Pentax Forum. There is of course no promises it will work here, but it isn't going to hurt to try either.
05-14-2013, 06:38 AM   #5
mrNewt's Avatar
Do you have a picture of that chip?
If your focus ring is damaged, it might create problems with proper focusing.
Have you tried other lens on your K-01? Do they work OK?
05-14-2013, 07:04 AM   #6
QuoteOriginally posted by JimJohnson Quote
Yes,K-01 has sensor dust removal utility. Very loud, it loud and not like K-5. Always open when turning off camera.
05-14-2013, 07:09 AM   #7
Na Horuk's Avatar
Very odd. You should get replacement under warranty.
05-14-2013, 07:13 AM   #8
QuoteOriginally posted by mrNewt Quote
No i dont have picture. I saw it but forget to take picture. Focus ring was ok. He clean it and oilled.But still problem. And after other lenses work well on K-01. They say chip problem.
05-14-2013, 07:16 AM   #9
mrNewt's Avatar
QuoteOriginally posted by haaldemir Quote
If other lenses are working than your K-01 is just fine. Try and return the XS lens if you have warranty.
If you can't ... ... hope you didn't spent too much on it.
But if is a chip caused because it was hit, it might not be covered under warranty ... .
Maybe you can still use it in MF mode with focus peaking.
05-14-2013, 07:39 AM   #10
first 40 mm Xs at f2.8
second 35 macro limited at F2.8
Pen focused
PENTAX K-01  Photo
PENTAX K-01  Photo
05-14-2013, 07:40 AM   #11
mrNewt's Avatar
Pen focused
Try and focus with the XS on manual focus - use peaking mode for better results.
05-14-2013, 07:43 AM   #12
No warranty so I will try this, thank you...
k-01, lens, mm, pentax help, xs
Wanted - Acquired: 40 mm xs Finger Sold Items 0 02-27-2013 08:46 PM
Pentax k-01 + 40 mm xs lens $299 at groupon Immunogirl Pentax K-01 27 12-23-2012 10:15 PM
40 XS vs DA 40 sewebster Pentax SLR Lens Discussion 81 12-03-2012 08:49 AM
35 dal or 40 xs? HoBykoYan Pentax SLR Lens Discussion 9 06-07-2012 09:30 PM
pentax 40 mm or sigma 24-70 mm Rons Pentax SLR Lens Discussion 6 01-08-2012 02:55 AM
All times are GMT -7. The time now is 04:57 PM. | See also: NikonForums.com, part of our network of photo forums!
