Two other petal teles: DA 50-135 and DA 60-250.
Basic Breakdown for the OP:
Tele Hoods can often cover the front of the lens from 99% of stray light by being about four inches long(Excluding 100mm+ front elements). Wide angles use petal hoods to cover as much as they can, at the lenses widest setting without having vignetting. Normal-Short Telephotos use Petal hoods as they tend to have a semi-wide view, and can benefit from the extra length in parts.
Basically, if it's over 100MM, you can probably get away with a circular hood. 35-100, you *could* use a rubber collapsible hood for a zoom, adjusting it's extension with the lens. Under 35, petal hoods are a must. If you're using a straight hood with a wide angle, I'll just presume it's either to merely protect the lens(As a straight hood would need to be quite small, or absurdly wide at this point), or because you don't entirely grasp what a hood is for.
In theory, though, a Tele would still benefit more from a petal hood. But let's put it this way, you bought a DA 560. In order to cover all unneeded light, you'd need a over hood half the size of the lens. A bit bulky, to say the least. Best to stick with 99% blockage at 1/4 of the size.
Originally posted by aoeu If the front element rotates
the hood can only be circular.
This doesn't make sense in all cases. Bayonet hoods aren't affected by the filter ring.
