05-28-2013, 06:47 PM   #1
how to know if k5 needs an update and where to get disc?
I see it referenced in threads, firmware u update. How do I know if I need one?
Also, how would I go about getting a disc that normally comes w the camera? I bought it used from Adorama last year.
05-28-2013, 06:53 PM   #2
Start the camera while holding down the menu button and it will show the firmware version. If it's < 1.14 then you should update it (instructions found on our homepage).
The discs aren't that easy to get, but you might be able to talk a fellow owner into sending you an ISO
05-28-2013, 07:11 PM   #3
Wow, maybe that's why I am having such trouble with the AF. Version 1.01.
I will do the update Nd put out an ISO, maybe I will get lucky. Thank you!!
05-28-2013, 10:29 PM   #4
vagrant10's Avatar
what kind of trouble are you having? specifically, under what conditions are you having trouble w/ the AF? it will be helpful to know what settings you have on the camera like what type of focus points you are using, what focus mode your cam is set to, what lens you are using, and how dark of an environment you are having the most problems with. also, let us know what your subject matter is... sorry for the long requests, but that will be the best way to get advise that actually helps you.
camera, pentax help, photography, update
How to know if my K-5iis is getting optimal focus? Kurt Euler Pentax SLR Lens Discussion 7 03-25-2013 09:39 PM
Where to get start when it comes to learning "the how" jtkratzer Troubleshooting and Beginner Help 44 07-22-2012 04:43 PM
Wanted to know if their is any way to get back the deleted photos? caedmon General Talk 4 01-25-2012 08:50 AM
Anybody know off hand how to remove the focusing ring on an A 50mm f/2.8 macro? Steinback Pentax SLR Lens Discussion 3 09-17-2011 07:33 PM
How do you know how much flash to get? justtakingpics Flashes, Lighting, and Studio 29 04-06-2011 07:59 AM
All times are GMT -7. The time now is 05:18 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
