Originally posted by VoiceOfReason Micro SD simply is NOT the way to go on the card. You might get something like an Eye Fi pro so you can do transfers wirelessly to the tablet, but you're not going to get good performance from a micro SD card in your camera.
I am aware a bog standard Micro SD card is only class 2 or 4. But I have acquired a Sandisk Ultra card which is rated as Class 10, and can't see why this wouldn't provide reasonable performance. Rated read speed is 30Mb/s. Let's, for argument's sake, halve this to 15Mb/s for the write speed.
I believe the K-x write speed tops out in the 10-15Mb/s range, so the card write speed should be suitably matched to the camera.
My problem is: are micro SD cards generally troublesome in Pentax cameras, or is it that it is a 32Gb card (which is at the top of the K-x's recommended card size), or is there something specific to my setup?
What I do need to check when I get home tonight is the firmware version on my K-x. I may not be on the latest version 1.03 which was issued to improve SDXC memory card reliability, but could well help on other card types as well.
