05-30-2013, 09:48 AM   #1
dslr lens not focusing on AF
I have a Pentax K-7 and four lenses, three of which are DA* lenses. I am having trouble with my f-2.8 16-50 mm DA*. It will not focus on the AF setting on my K-7, my other lenses will, and my 50mmf-1.2 will focus with the cameras motor.I can manually focus the lens, and it will focus with my older model pentax with the cameras motor.I have cleaned the contacts on the lens and made sure it is fully mounted, and have manually focused the lens in MF setting to try and kick start the lens's motor all to no avail. I believe the lens motor is gone, is there a way to bypass it and use the camera motor to focus, OR what would it cost to have the lens motor replaced, OR is there anything else I can try?
Thanks
Barry
bear_649@msn.com
05-30-2013, 10:11 AM   #2
Docrwm's Avatar
SDM failure is what it sounds like for that lens, sorry. There is a hack that allows you to turn an SDM into a screw drive lens or you could have it repaired. Last time I read a report on repairs it was around $300.
https://www.pentaxforums.com/forums/pentax-slr-lens-discussion/208353-how-dea...m-f-2-8-a.html
05-31-2013, 05:40 AM   #3
QuoteOriginally posted by Grizbear Quote
Thanks
Barry
bear_649@msn.com
That's what I thought and I am not brave enough to try the hack, pentax should write a program for that!!
05-31-2013, 07:08 AM   #4
Docrwm's Avatar
Just wanted you to know what your options are for the lens. Repairing it is the other option.
af, cameras, da*, focus, lens, lenses, motor, pentax, pentax help
Manual Lens focusing issues (focusing screen) Akarak Troubleshooting and Beginner Help 15 01-25-2013 06:56 PM
Focusing Problem with 50mm Lens, not with zoom lens timdoyle91 Troubleshooting and Beginner Help 15 05-22-2012 10:43 AM
Low light/pitch black DSLR focusing LaurenOE Photographic Technique 7 05-12-2012 06:24 PM
Swap Focusing Screen from old SLR to DSLR nanhi Pentax DSLR Discussion 2 10-10-2010 01:58 PM
Pentax DSLR focusing screen Big Dave Pentax DSLR Discussion 17 12-03-2008 11:23 PM
All times are GMT -7. The time now is 02:05 AM. | See also: NikonForums.com, part of our network of photo forums!
