05-31-2013, 06:29 AM   #1
johnlewis804's Avatar
Pentax K20D focus problem
Hello
I'm having trouble focusing with my K20D .I can focus on things short range but when i try to focus on something at a distance it keeps hunting. I've tried it with 2 lenses and it's doing the same thing. HELP!!!
05-31-2013, 10:17 AM   #2
QuoteOriginally posted by johnlewis804 Quote
Hello
Has this always been an issue? If your lenses are F5.6 or slower, you might experience slow AF. Alternatively, your lenses may need calibration (unfortunately you can't do this through the menu on the K20D AFAIK).
05-31-2013, 10:42 AM   #3
If you're talking AF fine adjust, yes you can.
05-31-2013, 10:51 AM   #4
Thanks for the reply guys, It just started doing it this week, Seems like i cant focus on things at a far distance. I tried both my kit lens and my sigma lens and the camera keeps hunting in and out .
05-31-2013, 10:55 AM   #5
How would do AF fine adjustment?
06-20-2013, 04:25 PM   #6
zekewhipper's Avatar
There are differing schools of thought on how to do fine/micro adjustment for lenses. My suggestion is to research the various methods that you come across, and then choose the method that seems to make the most sense to you.
Are you trying to focus on the same things far away under the same lighting conditions? It could be that you don't have enough contrast or the AF system is having some other difficulty. Sometimes the simple solution to that is...
1) Turn the camera 45-90deg. out of the orientation you want to use for the shot
2) Lock focus
3) Reorient the camera back and take the shot
Cross-type AF sensors were invented to alleviate the need to use the common technique I elaborated on above. Traditional AF sensors have always been designed to be more sensitive when using the camera in landscape orientation, because a majority of folks take a majority of their shots that way.
06-20-2013, 07:45 PM   #7
audiobomber's Avatar
This simple focus chart has worked well for me: http://www.dphotojournal.com/focus-test-chart.pdf
focus, k20d, pentax help
SMC Pentax-M 50mm F1.7 focus problem? Deano1969 Pentax SLR Lens Discussion 9 06-17-2011 12:04 PM
Focus problem: K20D Ian Buick Troubleshooting and Beginner Help 2 04-23-2011 06:18 AM
k20d Lifeview Focus problem ckons89 Pentax DSLR Discussion 4 08-11-2009 08:21 AM
K20D Focus problem AdrianM Pentax DSLR Discussion 21 02-06-2009 06:55 PM
K20D+DA*50-135 focus ring problem. Steven Yampolsky Pentax DSLR Discussion 4 04-15-2008 06:36 AM
All times are GMT -7. The time now is 12:20 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
