05-31-2013, 11:13 AM   #1
K2DMD questions.
I hadn't expected to own one of these and was pretty sure that it would need help, but here it is.
It obviously needs to go to Eric as the ASA ring is stiff to say the least. I got it set to 200 which means that film can be used from 50-800 with the compensating ring.
The other issue is that the metering doesn't seem to turn off. The light on the back stays on until the batteries drain.
As I prepare to return to film the bodies are getting stacked up. The MX, the Super Program, the P3n, the ZX-L with battery grip and now this. Which gets first silver . . .
05-31-2013, 11:29 AM   #2
I probably did it to myself by pushing the battery check button too hard before learning its real purpose. I have now read and printed the K2 and K2DMD manuals.
I need Eric's help with this one and can't find a link I have seen.
05-31-2013, 12:52 PM   #3
Home
05-31-2013, 01:30 PM   #4
builttospill's Avatar
Congratulations on the new acquisition. The K2 DMD is one of my favorite cameras.
I'm not sure what your questions are with the exception of Eric's website, which was answered above. Is there anything else we can help you with?
05-31-2013, 05:13 PM   #5
Why is the red LED on?
When I ask Eric should I say that I don't care about that feature if a new switch isn't available?
06-01-2013, 10:49 PM   #6
gofour3's Avatar
QuoteOriginally posted by aoeu Quote
When you press the battery check the red light indicates the battery is ok. If it is on all the time the button must be stuck in, which explains why your batteries are draining. Pressing the battery check button too often drains the batteries.
Phil.
06-02-2013, 04:45 AM   #7
Arjay Bee's Avatar
QuoteOriginally posted by gofour3 Quote
The classic researchers' dilemma - performing the test (research) alters the context of that which you are testing. Another example is using a pressure gauge to test the air pressure in your tires. The pressure drops every time the gauge is used.
06-02-2013, 01:38 PM   #8
Thank you Eulogy for the link.
Using a sharp sewing needle I managed to pop the button out and after ten frightening minutes managed to clear away some gunk.
I shot a roll of old film today and mostly used the Samyang 14mm f1:2.8.
The K2DMD is worth the trip to Eric on GP.
Peace, everyone
aoeu
film, pentax help
Pentax K2DMD Dent in prism Baard-Einar Pentax Film SLR Discussion 8 04-09-2012 11:00 AM
Found on a Japanese webpage: K2DMD in *chrome*! ChrisPlatt Pentax Film SLR Discussion 10 08-23-2011 04:47 PM
Pentax K2DMD Motordrive / MX Motordrive gofour3 Pentax Film SLR Discussion 5 04-26-2010 06:08 PM
All times are GMT -7. The time now is 11:47 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
