06-03-2013, 12:57 AM   #1
Is this lens flair?
Hi all
I took the photo below of my daughter a couple of weeks ago. You'll notice something in the top left corner where you can see the shape of the aperture blades. You can see the large obvious one but then also the smaller highlights within this e.g. some bits on the swing in the background.
Personally, I quite like it. However, no idea what causes it. Can anyone explain? Is this lens flair? The photo was taken with my Tamron 28-75 and it had the hood on and also a UV filter if that makes any difference. I took a few photos that day and a handful had the same thing on them but never seen it before or since.
06-03-2013, 01:55 AM   #2
geomez's Avatar
The big ones are flare, the little ones are bokeh.
06-03-2013, 02:04 AM   #3
geomez's Avatar
TECHNICALLY, the little ones are "Circles of Confusion".
Circle of confusion - Wikipedia, the free encyclopedia
06-03-2013, 02:09 AM   #4
I thought the "big ones" were called 'ghosting' and not 'flare'. Flare would reduce contrast over the whole image. No?
Ronnie
06-03-2013, 02:50 AM   #5
Digitalis's Avatar
QuoteOriginally posted by ronnies Quote
Thanks to modern lens coatings that are designed with the express purpose of maintaining contrast under these situations, no.
06-03-2013, 02:53 AM   #6
Stone G.'s Avatar
Ronnie
That is also how I would use terms. To me, internal refexions cause 'Ghosting' while light from strong sources just outside the field of wiew may scatter and cause a milky 'Flare' over most or all of the image?
06-03-2013, 03:17 AM   #7
Having searched for ghosting and flaring this seems like a pretty good overview of it all:
Understanding Lens Flare & Ghosting - Music Photography
06-03-2013, 03:50 AM   #8
Modern coatings are going to reduce flare but they do not eliminate it completely. They also don't change the definition of the term 'flare'. :-)
Ronnie
06-03-2013, 04:12 AM - 1 Like   #9
falconeye's Avatar
I am no native speaker, but ...
I think flare is the more general term for any kind of light attributed to scattering within the lens. While ghosting and haze are the more specific terms for visible artefacts and reduction of contrast.
It seems wikipedia uses the same notion.
And the ghosting lens effect filter in photoshop is called "lens flare...".
But others may use different notions.
And btw, it is flare, not flair. Flair has a completely different meaning...
06-03-2013, 04:25 AM   #10
So in summary then it is a result of me shooting almost directly into the sun. Doing a bit of research it seems that could be quite expected with this lens so no problems, at least I have learnt something. Thanks for the responses.
06-03-2013, 04:32 AM   #11
JimJohnson's Avatar
QuoteOriginally posted by thechumpen Quote
DON'T use UV filters to 'protect' the lens - about the only two filters that cannot be duplicated by the electronics within current digital cameras are polarizers or neutral density. Extra optical surfaces only degrade the image. DO use a lens hood.
06-03-2013, 04:34 AM   #12
QuoteOriginally posted by JimJohnson Quote
Yeah I've been reading about that and have decided to remove my UV filters (although there was one on for this pic taken a few weeks ago). I do always use a lens hood though.
06-03-2013, 09:47 AM   #13
geomez's Avatar
Agreed
06-03-2013, 10:20 AM   #14
utak's Avatar
So...I wonder if this is lens flare? I've always assumed that the left hand side of this photo was caused by light reflecting off oil inside the lens....
06-05-2013, 03:58 AM   #15
VisualDarkness's Avatar
QuoteOriginally posted by utak Quote
It looks like some kind off reflection from an element or maybe the interior of the lens. I guess the light source is high up the right side.
camera, lens, pentax help, photo, photography
Is this vivitar lens as valuable as I think it is? ripit Pentax SLR Lens Discussion 10 10-16-2011 07:59 AM
is this lens fungus? apakoh Troubleshooting and Beginner Help 13 07-31-2011 09:48 AM
Bought my first pentax lens, this is the one in this database right? Lulerfly Pentax SLR Lens Discussion 24 11-06-2010 01:54 PM
why is the camera doing this with this lens? momof4 Pentax SLR Lens Discussion 6 12-10-2007 01:00 PM
All times are GMT -7. The time now is 04:53 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
