Show Printable Version 21 Likes Search this Thread
06-07-2013, 09:53 AM   #16
QuoteOriginally posted by JinDesu Quote
Was this done with manual focus? Do you have a full size image or a 100% crop of that newer shot?
Auto Focus, top center point (think it would be pointless to do center given the subject lol)
F 5
1/125
ISO-320
06-07-2013, 09:58 AM - 1 Like   #17
altopiet's Avatar
Are you thinking front focus?
EXIF says f5, thus a little bit more depth of field, so the subject is still in focus, but if you look at the table it seems as if actual focus is more to the front of the subject...?
06-07-2013, 10:01 AM - 1 Like   #18
JinDesu's Avatar
QuoteOriginally posted by altopiet Quote
I'm not sure where the focus is landing exactly, so that's why I prefer manually focusing the lens on a tripod with liveview. By taking focus out of the equation completely, we can help narrow down the flaw.
06-07-2013, 10:11 AM   #19
Thanks for that. Let me try again with manual focus, will post results shortly.
06-07-2013, 10:21 AM - 1 Like   #20
JinDesu's Avatar
QuoteOriginally posted by dmazimoto Quote
Take your time, and use 2sec delay or 3s remote shutter.
In general, it can take some getting used to when shooting autofocus - especially in dim light or confusing situations. I have spent 2 years with my k-x, and I get solid focusing because I know it so well. With my recently purchased k-01, I have trouble with the autofocus sometimes, and I take longer to shoot.
I highly suggest checking the lens with manual focus, then testing the focus fine adjustment requirement to see if you can get the lens to focus accurately automatically. If fine focus adjustment doesn't work, then you may have to get the body or the lens checked out.
Do you have any other autofocus lenses?
06-07-2013, 10:49 AM - 1 Like   #21
Na Horuk's Avatar
I'd just like to say that when I first got my K-r, I thought the camera can't do better, but as the years go by, I noticed that the biggest part of the equation was myself. Learning to use a complicated DSLR can take some time, but it will outshine any phone. Feel free to look at the photo sample tool on this forum and search for samples of photos taken with K-30 and that lens.
06-07-2013, 10:58 AM - 1 Like   #22
LFLee's Avatar
I will add a suggestion that try shooting in daylight instead of indoor lighting, and see if AF works.
Good that you ask question instead of yelling "PENTAX sucks!".
06-07-2013, 11:02 AM   #23
Just the kit lens.
06-07-2013, 11:11 AM   #24
QuoteOriginally posted by LFLee Quote
I did extensive research on Pentax before deciding on my K30 and I love the camera. I hope I can get this sorted for better quality.
06-07-2013, 11:17 AM - 1 Like   #25
JinDesu's Avatar
Just the kit lens.
Test the kit lens as well - at 35mm and 55mm.
For field testing, shoot in bright light (preferably sunlight) at a subject that is nice and contrasty that fills the center circle in your viewfinder. Make sure it is a stationary object, and shoot at 1/500s or faster to ensure that there is no motion blur, and that your natural sway doesn't shift the focus point.
For fine focus testing, there are several focus testing methods on the internet. My preferred method is:
1) Put camera on tripod, aim at contrasty subject that fills center of viewfinder.
2) Set fine focus adjust at 0. Turn off autofocus. Press shutter button halfway and check for focus confirmation (green hexagon).
3) Release shutter button (keep autofocus off, all settings the same), move your fine focus -10um and repeat to check for focus confirmation.
4) Repeat this until you reach the point where the focus confirmation will not work. This is the back focus limit of your lens.
5) Reset the fine focus adjust to 0, and then go the other direction (+10um). This will find your front focus limit.
6) Take the negative and positive value and add together, then divide by 2. This will give you the focus adjustment that centers the lens.
There are multiple other methods, and I have found that they generally come out similarly.
06-07-2013, 11:40 AM - 1 Like   #26
aleonx3's Avatar
Looking at the first picture, it looks like a combination of several things - the lens has shown some slight front-focusing issue (instead of the faces, the sharpness is on the black T-shirt); also shallow DOF (moving further away from the subject may help to increase the DOF); a faster shutter speed (1/25) may help as well.
06-12-2013, 01:56 PM   #27
Hey guys a bad storm hit right after my last post so I was offline that day, then left for Houston. I've been slammed with work but working on the setup to get my camera's focus back in shape. I do feel the lens I am using is "loose" and the focus and aperture rings have quite a bit of play compared to my M42 Takumar. I didn't notice until today it was that loose and not sure if that affects focusing (I'm sure it does). Anyways, I'll post pics tonight, and again thanks to everyone that responded and is trying to help me, much appreciated
06-13-2013, 05:26 PM   #28
Ok finally it stopped raining and power is back on (it's been raining when I get out of work past couple of days I've gotten out early).
Ok. I did the setup. Good lighting plus flash to ensure lighting was not the issue. I shot a receipt (didn't have a newspaper handy, sorry) at aprox 45 degree angle, max aperture and manual focused dead center. The tro crops attached are of the center of the images. To me they seem in focus but the fuzziness is still there.
Shoe Brush, 45 degree angle, center focus (manual), F1.7, ISO100, 1/180, flash on
Receipt, 45 degree angle, center focus (manual), F1.7, ISO100, 1/180, flash on
This is driving me nuts. My dads old Sony P/S is shooting sharper than my DSLR
EDIT: I was going to continue testing but I'm kind of bummed out at the image quality.
EDIT AGAIN: These were taken on a tripod as well.
06-13-2013, 11:48 PM - 1 Like   #29
altopiet's Avatar
Can't see the images...?
06-14-2013, 06:16 AM   #30
Sorry
50mm, auto, camera, images, k30, lens, pentax help, photography, results
Need Help Shooting Spider Webs (Sample Photos Attached) Heie Photographic Technique 11 05-29-2013 05:15 AM
Sample images from imaging resource: K30 vs K5IIs kesong Pentax DSLR Discussion 15 11-05-2012 01:34 PM
Pentax K30 vs Sony SLT-a57 sample Images robwill Pentax K-30 & K-50 5 07-12-2012 05:50 PM
K7 fuzzy images bisjack Pentax DSLR Discussion 11 10-28-2009 01:27 PM
manual shooting help: fuzzy images: 200mm 41ants Troubleshooting and Beginner Help 16 10-28-2009 04:45 AM
All times are GMT -7. The time now is 11:49 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
