06-14-2013, 10:55 AM - 1 Like   #31
f/1.7? Excuse me, but what did you expect? You need to stop the lens down.
PS It looks as if you focused just a bit too far.
06-14-2013, 11:15 AM   #32
QuoteOriginally posted by Giklab Quote
What about the brush? The image still looks fuzzy. I understand about stoping down, but every review I read about this lens says its sharp wide open, and I've seen samples at 1.7 online that look remarkably better than mine. If the lens is this bad wide open then why even buy fast lenses?
06-14-2013, 02:49 PM   #33
This is the best I could get, image quality wise, at F5, 1/500sec, ISO 500. I've attached the photo and the center 100% crop. I guess I either just suck or this lens is no bueno wide open. My K30 doesn't seem to be too good past ISO800 either, noise-wise.
PENTAX K-30  Photo
06-14-2013, 10:59 PM - 1 Like   #34
altopiet's Avatar
Do you shoot RAW or JPEG? If JPEG, what is your JPEG settings in camera?
06-15-2013, 03:24 AM   #35
JPEG 16M Fine
06-15-2013, 04:18 AM - 1 Like   #36
altopiet's Avatar
If you go into "info", custom image setting(top left), try the "bright" setting, but change the sharp "s" to fine sharp "fs", and see if that makes a difference. You can even increase sharpness further by another 3 or 4 points in the fine sharpness setting, but I would not recommend that...
06-16-2013, 05:47 AM   #37
QuoteOriginally posted by altopiet Quote
I have aK30 can't find the fs anywhere. I did change image to bright and that makes the pictures look a bit better thanks!
06-16-2013, 05:52 AM   #38
QuoteOriginally posted by JinDesu Quote
Test the kit lens as well - at 35mm and 55mm.
For field testing, shoot in bright light (preferably sunlight) at a subject that is nice and contrasty that fills the center circle in your viewfinder. Make sure it is a stationary object, and shoot at 1/500s or faster to ensure that there is no motion blur, and that your natural sway doesn't shift the focus point.
For fine focus testing, there are several focus testing methods on the internet. My preferred method is:
1) Put camera on tripod, aim at contrasty subject that fills center of viewfinder.
2) Set fine focus adjust at 0. Turn off autofocus. Press shutter button halfway and check for focus confirmation (green hexagon).
3) Release shutter button (keep autofocus off, all settings the same), move your fine focus -10um and repeat to check for focus confirmation.
4) Repeat this until you reach the point where the focus confirmation will not work. This is the back focus limit of your lens.
5) Reset the fine focus adjust to 0, and then go the other direction (+10um). This will find your front focus limit.
6) Take the negative and positive value and add together, then divide by 2. This will give you the focus adjustment that centers the lens.
There are multiple other methods, and I have found that they generally come out similarly.
When I do this what do I do with the number I get?
06-16-2013, 06:25 AM - 1 Like   #39
QuoteOriginally posted by dmazimoto Quote
Could you try moving the e-dials? On my K-5 it's set via the back dial.
06-16-2013, 06:29 AM - 1 Like   #40
JinDesu's Avatar
Set that number as your AF fine focus adjustment value, and it should make your lens focus accurately.
06-16-2013, 12:48 PM   #41
Thanks I'm trying that today!
06-25-2013, 05:18 PM   #42
narual's Avatar
Probably not this, but just in case... I used to see this when my wife used my camera. She wasn't pushing the button down halfway to focus first. Pushing it down all the way always left the images a touch out of focus from the excess shake.
Or did the fine focus adjustment fix it?
06-25-2013, 10:40 PM   #43
altopiet's Avatar
If you are in the "Bright" menu, you'll see that the sharpness setting is the bar right at the bottom. If you turn the rear e-dial to the right it will change to Fs "fine sharp" (page 157 of the manual)
06-26-2013, 05:54 PM   #44
QuoteOriginally posted by narual Quote
Not the auto focus, I have the same issue manual focusing. The adjustment didn't fix it either. I took the lens to get checked out at my local camera shop and there's nothing wrong with the lens. The repair man did say the lens was designed for full frame though, and that may be part of the issue I'm experiencing (I have no clue if that's accurate or not). I'm taking my camera in for check up next.
06-26-2013, 05:56 PM   #45
Thanks man. I adjusted that. I've never seen this it's like the picture has brush strokes (referring to my original sample image). I'm taking my camera in for check up next.
50mm, auto, camera, images, k30, lens, pentax help, photography, results
Need Help Shooting Spider Webs (Sample Photos Attached) Heie Photographic Technique 11 05-29-2013 05:15 AM
Sample images from imaging resource: K30 vs K5IIs kesong Pentax DSLR Discussion 15 11-05-2012 01:34 PM
Pentax K30 vs Sony SLT-a57 sample Images robwill Pentax K-30 & K-50 5 07-12-2012 05:50 PM
K7 fuzzy images bisjack Pentax DSLR Discussion 11 10-28-2009 01:27 PM
manual shooting help: fuzzy images: 200mm 41ants Troubleshooting and Beginner Help 16 10-28-2009 04:45 AM
All times are GMT -7. The time now is 03:21 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
