06-26-2013, 10:17 PM   #46
altopiet's Avatar
QuoteOriginally posted by dmazimoto Quote
Thanks man. I adjusted that. I've never seen this it's like the picture has brush strokes (referring to my original sample image). I'm taking my camera in for check up next.
You're right, it might be best to let them check it out and make sure that you don't have a faulty camera
07-04-2013, 01:04 PM   #47
Sorry for the delay between responses, but here is the latest.
Seems like stopping down (way down) the lens(es) solves it. I really don't have any expensive lenses but the ones I have need to be around F8 to be sharp (my kit WR 18-55 and my FA 50mm 1.7). Below is a sample taken at F/8 ISO-200 1/500 sec JPEG super fine, spot center auto focus. First full pic, then 100% crop and 200% crop just for giggles. I'm ok with the quality of this shot but I can't imagine shooting at F8 all the time, specially when I like shallower DOF. Any good zoom's anyone can recommend with fixed 2.8 apertures?
Also, can anyone tell me judging from the pic if I should still get my camera checked (I can't say I've shot at F8 ever so I'm not sure how sharp things should be at that aperture)? I have not had time to take it in. There is only one place here in town that will touch my Pentax and they're far from me Help is truly appreciated and to everyone that's given advice already, I thank you!
PENTAX K-30  Photo
07-04-2013, 02:34 PM   #48
Na Horuk's Avatar
I dunno, the FA should be sharp pretty much from wide open onward. The kit lens does have its sweet spot around f8, though, so that makes sense.
But if the aperture solves it, its probably not the camera's fault. Maybe you just have a slightly bad copy of the FA and the kit lens works normally, which overall gave you the impression the camera is bad.
07-04-2013, 05:08 PM   #49
JimJohnson's Avatar
Test your camera for the possibility of back (or front focus). I suggested one such test that doesn't take more than 20-30 minutes if you read the directions slowly. Others have suggested other tests. Surely such a test would take far less time than driving to the camera shop you mentioned? You might not even need to go to the shop if the test comes out fine. Most of these tests involve nothing more than taking a picture of a test target in the manner indicated and evaluating the results.
There are a number of photographers in this Forum who regularly practice "f/8 and be there". They use aperture priority exposure, setting the camera at f/8, letting the camera decide shutter and ISO. f/8 has a sufficiently deep depth of field to cover a whole lot of focusing issues.
07-10-2013, 12:09 PM   #50
Solved the focusing issue (front focus) but as you can see the samples, the image quality is still less than desirable. Shot this outside, ISO 100 1/200 sec (on a tripod using a remote) F2.8, is this how images are to look when viewing at 100%?
07-10-2013, 12:47 PM   #51
JimJohnson's Avatar
Without specific lens information, I am guessing f/2.8 is wide open? Many lens are less sharp at their widest aperture. Most start getting sharper a couple stops from wide open with a 'sweet spot' near the center of the range. That said, some lenses perform better than others across their entire range which is a big reason for the huge price difference between lenses. For some idea of how your specific lenses perform, I recommend looking them up here in the Forum reviews. Up in the top menu bar there is a link for lenses. While not every Pentax compatible lens is there, the odds are good that you will find a listing for each of yours.
07-10-2013, 12:54 PM   #52
JinDesu's Avatar
I think he is still using the 50 F1.7. My M50 F1.7 is sharp at F2.8. My Sigma 50 F1.4 is sharp sharp at F2.8.
@Dmazimoto - can you shoot a subject that is not so angled? The chromatic aberrations due to OOF rendering makes it difficult for me to judge a few things. I suggest taking a picture of a wood post (has fine irregular features) or something similar in sunlight. Manually focus, of course - for perfect focus. The image you have above, the metal piece isn't that "bad". But I see jpeg compression artifact, plus it is a little dark to judge the details. Shooting a nice bright detailed subject, manually focused, will allow us to fully judge the image.
For me, I prefer shooting RAW and processing the jpeg so there I can control the jpeg compression. I am not as familiar with in-camera jpegs.
07-10-2013, 01:04 PM   #53
QuoteOriginally posted by JimJohnson Quote
Sorry it's my FA 50mm f1.7
07-10-2013, 01:06 PM   #54
QuoteOriginally posted by JinDesu Quote
I don't have any software to process RAW other than Irfanview. This image was originally in RAW. I'll step outside right now and shoot like you said.
07-10-2013, 01:07 PM   #55
JinDesu's Avatar
Ok that's fine. If you can (and hopefully you see this) - shoot a RAW image and e-mail to me. This is only because I only work with RAW from my k-x, and I haven't ever used in-camera jpeg.
But if not, that's fine. I'll do what I can to assist.
07-10-2013, 01:25 PM   #56
I take it you are not using a hood with the FA 50mm 1.7 lens.
I would personally use a hood. It should help contrast/sharpness a decent amount.
If that doesn't help, it could be that you just got a really poor copy of the lens. It really should be sharper then what is showing up.
As for jpg vs RAW. RAW always comes out a decent amount better then jpg. And to top it off, extracting the jpg from the RAW on your computer will also give you better quality then the in camera jpg.
There are a few free RAW processing programs out there.
RawTherapee Blog - I have not used this one.
you can also use Ufraw along with Gimp for photo processing:
UFRaw - Home
GIMP - The GNU Image Manipulation Program
07-10-2013, 02:35 PM   #57
Thank you! Sending over now.
07-10-2013, 02:36 PM   #58
QuoteOriginally posted by cyclone3d Quote
UFRaw - Home
Thank you for the links! No I am not using a hood, the lens is very recessed but if getting a hood helps I'll do that.
07-10-2013, 02:56 PM   #59
I'd just like to elbow in a vote for Rawtherapee.
07-10-2013, 10:59 PM   #60
I would defintely try with a hood. I never used to use a hood except on my 18-55 and then I got a few older lenses that came with hoods and it was night/day with the hoods on vs off.
Now I use hoods on every lense I have except for my 55mm macro since the lens basically has a built in hood because the lense is so recessed.
From my experience if the front lens element is not being shaded, it is not giving out near as good of IQ as it can.
You can always try using a piece of dark paper or something else to shade it and test before actually buying a hood.
50mm, auto, camera, images, k30, lens, pentax help, photography, results
Need Help Shooting Spider Webs (Sample Photos Attached) Heie Photographic Technique 11 05-29-2013 05:15 AM
Sample images from imaging resource: K30 vs K5IIs kesong Pentax DSLR Discussion 15 11-05-2012 01:34 PM
Pentax K30 vs Sony SLT-a57 sample Images robwill Pentax K-30 & K-50 5 07-12-2012 05:50 PM
K7 fuzzy images bisjack Pentax DSLR Discussion 11 10-28-2009 01:27 PM
manual shooting help: fuzzy images: 200mm 41ants Troubleshooting and Beginner Help 16 10-28-2009 04:45 AM
All times are GMT -7. The time now is 05:34 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
