06-08-2013, 07:43 AM   #1
What's the first default setting you changed on your K-30 and WHY?
As I work my way through the manual of my new K-30, I find it incredibly helpful on how you make various adjustments to the camera. It's less helpful when it comes to knowing WHY someone would choose to make a particular adjustment. In other words, what type of shot, or effect, are you hoping to strengthen by altering the camera's default settings? I thought a variety of responses from the experienced users on this site might be helpful to many. Thanks in advance.
06-08-2013, 07:54 AM   #2
Na Horuk's Avatar
Enable aperture ring, if you have any manual lenses.
06-08-2013, 08:56 AM   #3
Kobayashi.K's Avatar
It's a good idea to read the manual to begin with (it seems many of us haven't done that), because you will get an overview what is possible. After that, you can simply start shooting and when you encounter a 'problem' or you don't like the way how the camera is acting, you can adjust your settings.
It is almost impossible to give general rules because settings sometimes need extensive considerations. For example the file type for saving photo's (JPEG, RAW), processing images (in-camera or an external editor), or simply selecting an exposure mode (your style).
The discussions on PentaxForums can help you to find settings that better suits your style and habits. Use the search option to find info about specific topics.
Hope this helps.
06-08-2013, 10:44 AM   #4
JimJohnson's Avatar
agreed. Others: set the time, date and location; set the exif for photographer's information; make the RAW/Fx button do OVF DOF check; auto-focus with IR remote (see the next item); and make AEL only an exposure lock (might change that - right now I focus lock by flipping the switch from AF to MF after focusing).
06-08-2013, 10:47 AM   #5
JimJohnson's Avatar
QuoteOriginally posted by Kobayashi.K Quote
It's a good idea to read the manual to begin with.
Welcome to what seems to be a very small club! I have read my manual several times, and each time I find something new or something I misinterpreted on an earlier read. For what it is worth, I prefer the .pdf version of the manual.
06-08-2013, 11:47 AM   #6
Tako Kichi's Avatar
QuoteOriginally posted by JimJohnson Quote
I've been going through the PDF manual while waiting for my K-30 to arrive.
06-08-2013, 12:06 PM   #7
patrick9's Avatar
Yep... Then moved AF off shutter release button. Then I set the date/ time.
I have/use both But find I use the paper the most. I read the pdf while waiting to receive the K-30
06-08-2013, 02:24 PM   #8
hcc
hcc's Avatar
+1. Most important if you want to use MF lenses, especially older vintage lenses.
06-08-2013, 02:55 PM   #9
A useful feature of the PDF manual is obviously that you can search it with keywords. Manuals of almost all the Pentax camera's can be found on Operation Manuals Download : Support & Service | PENTAX RICOH IMAGING
06-08-2013, 04:26 PM   #10
patrick9's Avatar
A duh moment for me. I hadn't thought of the keyword search ability. I may be using the PDF copy more.
06-08-2013, 05:09 PM   #11
wullemaha's Avatar
same here
06-08-2013, 08:02 PM   #12
maxfield_photo's Avatar
Here's my list
  1. Disable half-press AF - I don't want the camera to refocus after I've composed. Especially for macro.
  2. Auto White Balance: GONE! - The lighting in my photos doesn't change on a shot-to-shot basis, why would I want my white balance to do so?
  3. WB Adjustable Range: OFF! - You stupid camera I just told you, don't &#@* with my white balance setting!
  4. Color Space: Adobe RGB - the JPEG files are bit bigger, but the color is much better (not that I shoot many JPEGs these days)
  5. EV steps: 1/2 stop - I just like half stops better, and it puts 1/180th (the max sync speed of the camera) between 1/125th and 1/250th, instead of 1/160th.
  6. Sensitivity steps: same as EV.
  7. Auto ISO: I don't think so - What I find acceptable, and what the camera thinks I will find acceptable are two different things. Plus auto ISO doesn't work well with manual flash, which is about all I do.
  8. Green Button in TAv and M mode: Aperture priority - I don't use it much, but when I do use the green button, I want it to leave my DoF alone. If I were a sports shooter though, I might choose Shutter priority.
  9. Aperture ring: allow - I have plenty of old glass that needs this, and sometimes I just like the tactile feel of turning an aperture ring, even when the lens has an A mode.
06-09-2013, 06:09 AM   #13
JimJohnson's Avatar
I'll do a followup.... I don't have the same needs as maxfiled_photo, but I too use 1/2 stop rather than 1/3 stops. Partly because if the 1/180 x-sync issue, but also because it is much easier for me to double and halve values in my head when I want to shift values between ISO, aperture and shutter, but keep the same exposure ... or bump exposure using 2 out of 3. I've got the 1/2 stop values memorized. And since I do post processing using Adobe software.... and the camera directly supports Adobe's color space... why not use Adobe RGB and DNG?
It may not have been the FIRST thing I changed, but it happened pretty quickly - I turn off all artificial sounds. If I felt I really needed it, I might turn the focus confirmation beep back on. Fortunately, I haven't felt such a need.
06-09-2013, 08:22 AM   #14
tclausen's Avatar
QuoteOriginally posted by patrick9 Quote
Another useful feature: you can stick the manual on your phone or tablet, and so always (without extra bulk) have it around when in the field and puzzled of the "gee, I wonder if I couldn't..." sort.
Have resorted to that a couple of times when I got the Q myself.
06-09-2013, 04:42 PM   #15
ramseybuckeye's Avatar
+1
The pdf is great because it is searchable
Because it is searchable you may find two sections that reading both helps to explain something better. Sometime the writers of the manuals assume the user already understands another part of the manual.
camera, default, k-30, pentax help, photography
What's the first thing you did with your Q when it arrived? Lowell Goudge Pentax Q 22 04-18-2013 03:24 AM
What's your level of confidence in the roadmap, and why? ephophex Photographic Industry and Professionals 7 06-04-2012 07:44 PM
What did you buy first and why? bakamera Troubleshooting and Beginner Help 19 06-11-2011 04:17 PM
What was your first camera and why did you get it? jct us101 Photographic Technique 84 07-19-2010 10:38 AM
What "imge tone" setting(s) do you use and why? wildman Pentax DSLR Discussion 9 02-20-2010 04:14 PM
All times are GMT -7. The time now is 10:10 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
