06-10-2013, 03:47 AM   #1
Kr firmware updated installed but....
Hi all. I have today updated my Kr camera with firmware 1.13. All is working fine until I attach my Tamron 70mm-300mm lens. On the screen there is the flashing "F--". I have found this website (need to translate as it is in French);
Pentax optio optiowp optiox k-m km *istd *istds ist istds dsmobile 600 versacam pocketjet photo browser 3 photo laboratory 3 hoya ricoh
I thought this can just be fixed by installing an older firmware. No this does not work! How can I fix this as I need my camera ready for Silverstone!
Any help would be much appreciated!
Thanks
Dino
06-10-2013, 05:33 AM   #2
The lens has an aperture ring.
Make sure it's set to 'A'.
06-10-2013, 06:35 AM   #3
G.T
... or no aperture transmission (i.e, is an old K/M glass), in which was you have to enable the use of the aperture ring (under the Advanced menu).
06-10-2013, 07:40 AM   #4
Na Horuk's Avatar
Enable aperture ring in the menu (I think its at the very end of the menu), and make sure the lens contacts as well as the camera mount are clean.
If the lens has an aperture ring (similar to focus and zoom rings, but with f- numbers on it), there is probably a button on it and you can push the button and set the lens to "A", this will give you more automation.
06-10-2013, 10:29 AM   #5
Silly me! After getting worked up, I took a break made some tea, then looked at my lens. The AF on the lens was in manual mode.....newbie error!
Doh!.. But glad i have found these forums, thanks all!
camera, firmware, kr, kr firmware, pentax help, photo
Updated Q firmware - one thing not seen mentioned anywhere... Kirill_est Pentax Q 4 11-30-2011 02:44 AM
SD card purchase with k7 1.11 firmware installed? oahutodd Ask B&H Photo! 6 01-27-2011 08:10 PM
Updated firmware Naturenut Pentax News and Rumors 10 05-04-2010 02:08 PM
most updated firmware? newuser Pentax DSLR Discussion 12 12-05-2007 11:49 AM
Updated to V1.02 firmware but... cruiserlan2000 Pentax DSLR Discussion 26 01-01-2007 11:15 PM
All times are GMT -7. The time now is 04:26 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
