07-04-2013, 01:54 AM   #16
Ceremonsen's Avatar
I wonder, do the cameras with fixed lenses have the same problem?
07-04-2013, 05:24 AM   #17
oxidized's Avatar
probably not, unless dust somehow managed to make it's way inside during assembly.
07-20-2013, 11:23 AM   #18
OrangeKx's Avatar
My K-x sensor was getting fairly dirty (had a couple of larger spots) so I got to exploring my options through this Forum and other places online. I did the Rocket Air (didn't help) and after some reading and video watching I began to get paranoid about cleaning the sensor (and I was wasting a bunch of time watching videos that didn't help much). I decided to man-up when I realized I had some artist brushes in the closet and got a very nice (soft) brush about 1/2 inch (1.5 CM) wide. I blew out the brush and raked it across a knife edge back and forth the get it cleaned out and managed to do a very good job of cleaning the sensor. I had to make a few tries at it cleaning/blowing the brush out before every cleaning. After each brush off I took a 4 second picture of a wall (moving the camera as I took the picture) and compared the results from each cleaning. In LR4 I could compare the pics side by side and see some dust moving around or being removed completely. I have one small dust spec that is giving me fits but I figure it's light years better than it was and all I had to do was a "dry clean". I agree one should be very careful, but with the proper tools and a bit of homework this is doable.
07-21-2013, 01:27 AM   #19
QuoteOriginally posted by Ceremonsen Quote
Since they're not airtight...
Even if it would be more difficult for the dust to get on the sensor, if it does happen removing it means disassembling the camera.
I'm using the O-ICK1 sensor cleaning tool, by the way. A safe, efficient solution - I wouldn't want to use wet cleaning.
10-01-2013, 12:09 AM   #20
Ceremonsen's Avatar
There's always a danger that it could be lubricant splatters. Then, a dry cleaning will make the sensor even dirtier.
Another question:
When we refer to "sensor" cleaning or swabbing, we actually talk about AA filters (anti-aliasing or low pass)
that will be brushed or/and wiped with a swab, and not the actual CCD or CMOS.
Some of the recent cameras, like Pentax K-5 IIS, lack these filters.
Does it mean that dust and lubricant splatters will go directly onto sensor?
How to clean it in this case?
pentax help, sensor
sensor cleaning DanLoc78 Pentax DSLR Discussion 12 07-23-2008 12:47 AM
sensor cleaning schmik Pentax DSLR Discussion 10 05-29-2008 09:33 PM
Sensor cleaning: Pec-Pads or Sensor Swabs gadgetnu Pentax Camera and Field Accessories 29 09-24-2007 10:52 AM
Sensor cleaning > Sensor Swab > void warranty? Twinky Pentax DSLR Discussion 2 07-28-2007 01:10 AM
Sensor cleaning adimundo Pentax DSLR Discussion 13 01-26-2007 09:20 PM
All times are GMT -7. The time now is 11:48 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
