06-10-2013, 05:44 PM   #1
geomez's Avatar
DA 10-17mm Hood Visible In Picture?
I took this picture the other day with my K-01 with a DA 10-17mm Fisheye mounted. The lens was at 10mm and SR was on. You can see two small black areas on the top and bottom left and along the top of the picture. I put the lens on my K-5 IIs and used the Composition Adjustment feature to try to replicate the framing. It was nearly identical.
Has this ever happened to any of you? Is it safe to assume that this is a result of the SR overcompensating the motion of the camera?
This is the only time this has happened to me and I have been unable to replicate this type of vignetting (outside of Composition Adjustment) no matter what I do. Could there be something wrong with my K-01?
Attachment 175740
06-10-2013, 05:55 PM   #2
Aristophanes's Avatar
Wow! I have never seen that with my FE.
Perhaps the camera was jostled and kinked the SR. Just wondering.
06-10-2013, 06:11 PM   #3
hcc
hcc's Avatar
I never see the hood with my DA10-17mm. Aristophanes might be right suggesting a kink of the SR.
06-10-2013, 07:02 PM   #4
I'm not sure I'm clear...so you were able to replicate this with your K-5iis using composition adjustment? If so, were you able to get the same effect on opposite corners? If the answer is no, I think you have a defective lens which is not aiming the center of its image at the center of the sensor. If yes, maybe lens is not defective, but not sure. I've never seen or heard of this with other copies of this lens.
06-10-2013, 10:01 PM   #5
geomez's Avatar
I am able to replicate it in every corner using composition adjustment. It seems to show equal amounts of the hood at the extremes of every corner, so I think it's pointing in the center.
06-11-2013, 05:27 PM   #6
When I have the time, I'll see if mine does the same and reply back.
06-11-2013, 08:45 PM   #7
QuoteOriginally posted by darylk Quote
geomez - Yup - mine does it too. I just played with my 10-17 and confirmed that it performs just like yours when sensor is adjusted to extreme limits and at 10mm FL. I think your lens is fine. We just need to do a good job of holding camera steady when shooting at 10mm to avoid SR reaching extreme limits. Best regards, Daryl
06-11-2013, 10:30 PM   #8
geomez's Avatar
I think my lens is fine too, it's the camera that I wonder about. I can't imagine the SR moving that extreme being a normal thing for the camera to do, especially having never heard of it nor apparently anyone else on here.
06-12-2013, 01:18 AM   #9
tclausen's Avatar
Interesting...I have never seen that happen either on my 10-17mm. I rarely use it fully open, though, so that may have something to do with it too?
06-14-2013, 09:57 PM   #10
QuoteOriginally posted by geomez Quote
I've never seen this on an actual picture, but I can reproduce it using the composition adjustment on my K-30. Of course, usually when I'm shooting with this lens at 10mm I'm more worried about getting everything lined up without getting my feet in the picture; I'm definitely not moving enough to stress the SR mechanism much.
10-17mm, adjustment, composition, da, k-01, lens, pentax help, picture, sr
For Sale - Sold: DA 10-17mm FISHEYE laert Sold Items 5 12-28-2012 09:56 PM
For Sale - Sold: smc PENTAX-DA FISH-EYE 10-17mm F3.5-4.5 ED IF in excellent Condition jjdgti Sold Items 6 04-13-2012 08:08 AM
For Sale - Sold: Pentax DA 10-17mm fisheye crewl1 Sold Items 2 01-09-2012 11:05 PM
For Sale - Sold: Pentax DA 10-17mm fisheye jgmankos Sold Items 2 07-26-2011 09:38 AM
All times are GMT -7. The time now is 10:14 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
