06-11-2013, 10:50 AM   #1
Pentax Kr - Memory Card Error
I know there have been other post of the same matter, however, most of them place the issue with a bad memory card. I've tried out several brand new memory cards (transcend 32 GB SDHC, ScanDisk Extreme 32 GB card and now just bought a 8 GB scandisk ultra) and all i get is a memory card error. These cards all work in my K-5 & K-7 that I have (and a hd video camera). The firmware has been updated to 1.12. I have been able to get a few of my standard 2GB ScanDisk SD cards to work, but that seems to be it. Anyone ever had this much issues? could it be the actually receptors in the camera that are the issue?
06-11-2013, 11:06 AM   #2
Have you tried formatting those cards in your K-r? That should hopefully fix the problem.
06-11-2013, 11:17 AM   #3
Hadn't thought of that, but I just tried it and it won't format, just gives me the memory card error issue. On another note, I found a old 256 mb kodak sd card laying around and that worked in it....It just seems like only the smaller cards are working. Is it just the fact that Kr's don't read the SDHC sd cards?
06-11-2013, 11:28 AM   #4
JimJohnson's Avatar
Location: Summer:Lake Superior - Michigan Winter:Texas Hill Country
QuoteOriginally posted by STLfan Quote
What is your firmware level? I routinely used Sandisk 32GB class 10 SDHC cards in my K-r.
Also, take a small flashlight and look down into the card slot and make sure you didn't bend any of the contact points.
06-11-2013, 12:13 PM   #5
Na Horuk's Avatar
If you have the latest firmware, the K-r should work with SD HC cards. I have never had it refuse to work with an SD card. The only problem i had was that one or two cards would occasionally give errors or fail to record data properly. Can you test those cards in other cameras? Did you make sure the write protection lever is in the correct position?
camera, card, cards, error, gb, issue, memory, pentax help, scandisk
Memory Card Error AussieTrev Pentax K-01 16 01-15-2014 09:58 PM
K5 Memory Card Error WightWalker Pentax K-5 5 11-13-2012 04:04 PM
Memory card error notice Tommy Armstrong Visitors' Center 3 09-09-2012 09:50 PM
Memory Card Error Pentax K10D Dutch_Member Troubleshooting and Beginner Help 6 04-02-2012 07:46 AM
Memory Card Error kcooper74 Pentax DSLR Discussion 2 02-18-2012 04:36 PM
All times are GMT -7. The time now is 06:25 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
