Originally posted by Banskojoe Any idea why this happened?
when you delete a file, its record is removed from the file system table of contents but the values of the disk sectors which were occupied by the file remain intact until these sectors are reused to write something else. Some reason your tv software is acting like a recovery tool, it is reading those sectors directly and building up the original files. In Camera formatting might zero all data or use computer to do that (zero format takes significantly longer time).
