06-16-2013, 10:39 AM   #1
Automatic horizon correction in K7 Pentax body
Hello again,
I was wondering whether some use this option in the K7 menu (I suppose it is available on the K5 and other bodies), and what is their experience about? As far as I'm concerned, I activated this feature on my K7 and found that many pictures were not vertically aligned despite I checked the image composition. Then I noticed that the level indicator in the viewfinder never indicated a correct horizontality though the image in the viewfinder seemed ok. I then made some tests by perfectly aligning the bottom of the viewfinder frame with a straight object and noticed again that the object was not aligned in the picture taken. My conclusion is that the level sensor is not correctly calibrated. I unchecked the automatic horizon correction in the menu and repeated the test, this time the object was correctly aligned.
06-16-2013, 10:43 AM   #2
Docrwm's Avatar
The artificial horizon can be out of sync and need adjustment. Your tests appear to indicate that yours needs adjustment.
06-16-2013, 11:00 AM   #3
scc
Yes, the problem is I don't find an option for calibrating it.
06-16-2013, 11:01 AM   #4
QuoteOriginally posted by scc Quote
There isn't one. Only a service center can calibrate it for you, unfortunately. Also, try updating your firmware, as that might also fix it.
06-16-2013, 11:21 AM   #5
scc
Thanks,
I already updated the firmware, it didn't help. Since this feature is not essential I don't plan servcing the K7 body though.
correction, image, k7, level, menu, object, pentax help, viewfinder
In-camera lens correction speed of K5 over K7 LowVoltage Pentax K-5 5 02-10-2011 03:48 PM
K-7 automatic Lens Correction? shang Pentax DSLR Discussion 3 07-16-2010 01:49 AM
K-7 Horizon correction. LeDave Pentax DSLR Discussion 2 12-11-2009 11:41 PM
Pentax K-7 'automatic horizon correction' feature ! Confused Pentax DSLR Discussion 5 06-17-2009 03:45 AM
Automatic lens distortion correction example PentaxPoke Pentax SLR Lens Discussion 6 02-03-2009 05:39 PM
All times are GMT -7. The time now is 02:10 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
