06-17-2013, 06:35 AM   #1
50-135 mount problem
My 50-135 suddenly seems to have a problem with it's mount. I hadn't used it for a couple of months after a journey to Surinam last autumn. I went for a shoot a couple of weeks ago and when I mounted the lens I had to use much more force than usual to turn the bayonet into it's place. After mounting it my camera (a K-5) went completely berserk, suggesting that there is a short circuit somewhere in the mount.
I went for a little investigation and found the following things:
- The lens behaves exactly the same on both my K-5 and my K10D
- Other lenses don't show this behaviour (tried 77ltd, 16-45, 18-135 and an old A400); they mount perfectly smooth and function like they should
- The lens mount doesn't show any defects or irregularities
- All shapes and distances within the lens mount are exactly the same as on other lenses
- When mounting the lens the bayonet starts giving more resistance when it's turned about halfway
- The lens is usable on my K-5 when I put it to MF and spotmetering, multisegment or centre-weighted make the camera go nuts
It seems to me like a mount failure like I said, but since there's absolutely nothing visibly wrong with the mount I'm quite puzzled. Anyone any suggestions?
06-17-2013, 07:53 AM   #2
Docrwm's Avatar
Sand in one of the button contacts that carries electrical and data signals from the lens to the camera is my best guess. Check to see if each of the gold color button contacts moves a bit as you press on them.
Marked 2 in the picture above.
06-17-2013, 08:00 AM   #3
jatrax's Avatar
QuoteOriginally posted by Thijssie Quote
You note that 'all shapes and distances within the lens mount are exactly the same', yet the fact that there is resistance when turning it indicates that something is out of spec. What did you measure with? You are dealing with extremely close tolerances and areas difficult to measure.
Look for any scratches or marks on the area where the resistance occurs, you might be able to tell if something is bent. And I would try mounting a cheap extension tube rather than putting on the camera. You won't mar the camera mount and you can look through the tube and might be able to see if anything is binding. You can also try 'bluing' which is a dye that machinists use to tell where something is rubbing. A quick substitute is a magic marker, just mark up the area in question and then try to mount again. The areas that bind will rub off the marker. Again, do not do this on the camera use an extension tube.
bayonet, camera, couple, k-5, lens, lenses, mount, pentax help
DA* 50-135 QuickShift problem? kyprous Troubleshooting and Beginner Help 3 06-11-2013 04:40 PM
what would you get 18-135,50-135 or 50-200 WR pearsaab Pentax SLR Lens Discussion 13 06-22-2012 05:50 AM
confirm a 50-135 problem skoobie Pentax SLR Lens Discussion 7 06-20-2012 12:34 PM
Move from 18-135 to 16-50 + 50-135 DA* Lenses brosen Pentax SLR Lens Discussion 34 11-08-2011 05:11 PM
DA* Focus Ring 50-135 Problem AMBIVALENCE Pentax SLR Lens Discussion 2 06-21-2011 09:25 PM
All times are GMT -7. The time now is 07:38 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
