06-23-2013, 06:10 AM   #1
Old Lenses and K30
Hi,
new to the forum - so this may have already been answered (but I haven't found it yet....) so if already here, please let me know!
Anyhow looking to buy a K30.
I have a couple of old Tamron Lenses with Adaptal adaptors (a 500mm mirror lens - reviewed on this site and a 35-210).
I want to buy the K30 as it looks like a good solid camera and from what I can ascertain, i should be able to use my old lenses. (I have an old Ricoh KR10 right now, but it hasn't been used in over 15 years...)
Unfortunately, took the lenses down to the local camera store to try but we couldn't get the lenses to work with the K30 (though the guy was impressed that my lenses are in excellent condition).
Am I supposed to buy some other adaptor or do I need to put the camera into a special mode to get my old lenses to work?
If I know that they will work for sure, I'm keen to go buy the K30. OF course I'd buy the K30 with a "new" lens as well as my lenses don't have the AF capability.
Hope you might be able to help out.
=F.
06-23-2013, 06:56 AM   #2
See this article:
https://www.pentaxforums.com/forums/pentax-lens-articles/110657-how-use-meter...k-x-k-7-a.html
06-23-2013, 08:49 AM   #3
jatrax's Avatar
QuoteOriginally posted by frangutz Quote
If the lenses mounted properly on the camera then they will work. The most likely explanation is that the menu setting to allow use of the aperture ring was 'off'. This is the default as it is not needed with modern DA series lenses and the demo camera in the store most likely has not had it turned on. Read the article Adam posted for more explanation. The setting on the k-30 is Menu>C>4>23 "Using Aperture Ring" Set this to on.
06-23-2013, 08:54 AM   #4
patrick9's Avatar
Welcome and Enjoy your K-30 when you get it
06-23-2013, 09:16 AM   #5
bluenose's Avatar
This information from the Pentax USA site may also help. Using K-30 With Older Lenses | Pentax Support
Regards
06-23-2013, 01:36 PM   #6
Hi thanks for all the responses.
I'm pretty confident that this is going to work then. Look forward to buying the camera!
F.
camera, k30, lens, lenses, pentax help, photography
Upgrading K5-old or K30? kace Pentax K-30 & K-50 9 12-21-2012 11:33 AM
New K30...Old lens??? BerndM Pentax K-30 & K-50 5 11-25-2012 01:30 PM
K5 and old K Mount lenses David J Visitors' Center 8 02-20-2012 10:24 AM
Old lenses getting rare... and expensive mediaslinky Pentax SLR Lens Discussion 35 09-18-2011 09:51 AM
Kr and old K lenses fazalabbas Pentax K-r 14 08-11-2011 04:33 PM
All times are GMT -7. The time now is 04:15 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
