Originally posted by Hope9811 I understand "how" the camera is using the metering but I don't know "which" metering would be a good one for a beginning user for the best results. It was set on center weighted for these pictures and I still have it there because if I was centering my shots, then I figured this would be a more accurate metering method. It was mentioned here that should have it on matrix metering but I can't find any info on "matrix" metering.... mine has multi segmented, center weighted and spot metering. Is center weighted the right one for most situations? I am using a K-x.
Matrix metering is the same as Multi-Segment metering, Pentax just uses a different name. There's no "best" metering method. You need to know how each works, and how to use them. The camera can measure and determine exposure, but has no clue about the photographer's intent. That's why people sometimes use the different metering modes, as well as Manual exposure or Exposure Compensation.
Most photographers have a preferred (default) metering method, and most probably use Matrix. I have several cameras. I use Matrix Metering predominately with all of them, all that is, except for the K-x. I found that the K-x exposed a bit hotter than my older Pentaxes, and frequently burned the highlights in Multi-Segment mode. I found it easier to judge metering in CW mode, and that became my default for the K-x.
You didn't quite answer my question about focus method. You addressed constant focus vs. single focus, but not the AF point. I use all; Center Focus point, Manual Focus, Select AF, Auto AF. I believe that Center Focus & Recompose is best for general use, especially with the K-x, which lacks illuminated focal points.
Your photos look good, but it's hard to judge focus with small photos. I don't think there's anything wrong with your camera, I think you just received bad advice from your teacher regarding AF-C. Default should be AF-S for stills, AF-C is for action.
