06-28-2013, 06:05 PM   #16
You can check that by using an AF adjustment chart.
I've compiled some AF adjustment hints, including some pointers to charts with their pros and cons.
Thank you!
06-28-2013, 06:46 PM   #17
Just1MoreDave's Avatar
QuoteOriginally posted by Skeeter Quote
So perhaps I don't need to adjust at all??? Just apply more sharpening in PP?
Sharpening won't fix out of focus.
Follow one of the reasonable suggestions for a target. The reasonable ones give the camera only one perfect place to focus, with something easy to lock onto, probably in daylight, with the camera on a tripod. Get the camera to focus with normal AF and take a shot. Then switch to live view and get the contrast detect AF to do the same thing. If those shots are consistently different, with phase-detect AF missing by about the same amount, you need to adjust.
06-28-2013, 07:51 PM   #18
Otis Memorial Pentaxian
QuoteOriginally posted by Just1MoreDave Quote
Thank you, Dave for adding this comment. I frequently read statements that all manner of ill can be corrected in PP. We have a saying in my field (software development), "Garbage in...Garbage out". There are limits to what you can do if you have very little to work with.
06-29-2013, 03:47 AM   #19
Na Horuk's Avatar
Well depends. You need to adjust if your AF is wrong. If your AF is right and it still seems soft, then you need to sharpen, add clarity, add contrast, tricks like that.
adjustments, af adjustments, cameras, da, dyslexic, generation, k30, pentax, pentax help, tune
pentax kr af adjustments crabe919 Pentax K-r 10 02-28-2013 09:59 AM
Do AF adjustments add up? djc737 Pentax SLR Lens Discussion 4 10-28-2011 07:41 PM
Seductive Sexuality in Fashion the Norm Not the Exception benjikan Photographic Technique 6 06-17-2011 12:50 PM
K-7 AF Adjustments v5planet Pentax DSLR Discussion 2 02-14-2011 08:06 PM
K20D AF adjustments ManuH Pentax DSLR Discussion 14 09-11-2008 02:47 PM
All times are GMT -7. The time now is 11:29 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
