07-07-2013, 12:32 PM - 1 Like   #16
Howdy,
I've noticed this issue myself. I guess it's time to contact Support. Aperture motor failing would make sense because whenever this happens, I hear a weak click before the shutter opens/closes.
07-26-2013, 06:17 AM - 1 Like   #17
Oh wow this looks like an epidemic. I just sent my K-30 in for repairs for the exact same reason. It wasn't even a year old. So much for "rugged and reliable" Pentax...
08-02-2013, 03:54 AM - 1 Like   #18
I have got response from service. Whole shutter-mirror-aperture mechanic needs to be replaced. Since I don't have warranty, it will cost over half price of the body :/
08-06-2013, 07:02 AM - 1 Like   #19
Mine just came back from service. The whole body was replaced under warranty.
08-06-2013, 07:51 AM - 1 Like   #20
altopiet's Avatar
Is it possible that it might be a problem with some of the initial batch of K-30's? It might be good if everyone with similar problems can add their serial numbers and date of purchase, to try and establish a pattern.
I bought my K-30 in November 2012, have about 12000 actuations, and don't have any problems at the moment. My serial nr 4370406.
08-18-2013, 06:46 AM - 1 Like   #21
midero's Avatar
This seems to be a pretty widespread problem. Here is another thread dealing with the same issue and the same apparent fix.
https://www.pentaxforums.com/forums/general-technical-troubleshooting/227894-...exposures.html
Mike
08-18-2013, 10:13 AM - 1 Like   #22
Otis Memorial Pentaxian
QuoteOriginally posted by qwertyazerty Quote
Defect rate (according to Consumer Reports) is same or better than most of the other brands, though that is not saying much. This is true for even the pro-level Nikon and Canon product.
10-30-2013, 10:56 PM - 1 Like   #23
altopiet, mine was purchased new from B&H in February 2013 and I'm having this exact problem. After 20 years of shooting film in manual cameras, I thought these random underexposures were my own doing somehow because I didn't understand fancy DSLR metering (even though I've metered on film sets forever, I somehow thought I was doing something wrong...).
Anyone that has sent there K-30 in for this service, can you report on the turnaround time? I was quoted up to 5 weeks by the guy at the repair facility today (super nice guy but 5 weeks is insane).
10-31-2013, 12:29 AM - 1 Like   #24
adwb's Avatar
In the UK it took 4 weeks and a unholy row to get mine back under warranty and I use it as a second body as a full time pro, I had to send a very forceful email to the Ricoh-Pentax CEO to get them moving. They replaced the main board so it came back as a new camera electronically
10-31-2013, 04:15 AM - 1 Like   #25
altopiet's Avatar
I'm over 20K clicks, no problems, but nearly out of warranty, so holding thumbs...
11-04-2013, 12:12 AM - 1 Like   #26
Hi
I have exactly the same problem.
I am now on vocation in Korea , so I shoot a lot.
Once in 4-5 days I have few hours of this problem.(dark images with the same exif) the only bypass I found is using high speed mode . Usually the first photo in the series turns out to be dark while the following are ok. After few hours of shooting the problem goes away. I think I hear strange sound when those dark images are shot.
I consider visiting the service here in busan but how can I report problem which is random with low rate of ocurances ? Have any of you had this problem solved by simple means? Clening contacts ,firmware etc (just before I go to the service)
11-04-2013, 12:32 AM - 1 Like   #27
altopiet's Avatar
QuoteOriginally posted by levin1982 Quote
Hi
How many clicks do you have on the camera and after how many clicks did the problem start?
11-04-2013, 01:11 AM - 1 Like   #28
QuoteOriginally posted by altopiet Quote
Hi
I am not sure regarding the counter when the problem has just started.
The current EXIF shows
Manufature Date2012:08:03
Shutter Count9,870
What do you think ?
11-04-2013, 02:39 AM - 1 Like   #29
altopiet's Avatar
Hi
Shutter Count9,870
What do you think ?
I'm trying to figure out if it is a bad batch, and from which period (serial nr...manufacture date), more or less. As I've already said, I have over 20K clicks, mostly shot High continuous sport shots, of which over 5K clicks was in one day, and no problems so far. You are at about 10K clicks and the problem only starting now... Seeing that I hammered mine a bit in the year since I've bought it, and it's still going, I hope that mine is from a "good batch". It would be interesting to get such info from other users, because it might help in the end with proof for warranty repairs, seeing that it seems to be not a very consistent problem. On mine I've only got another month on warranty, but unfortunately the next 2 months won't see me using it much, so my luck might run out if the same problem arises with mine...
11-09-2013, 09:09 AM - 1 Like   #30
Hi
I aproached repair shop with this problem, but they just fail to reproduce . so i got my camera back with no work done on it.
Any ideas what can i do?
It seems my problem happens only when i use battery which was charged overnight
camera, exposure, hurt, image, pentax help, photography, thanks, troubleshooting
K5 Underexposure problem with Aperture 3 Bigkidneys Pentax K-5 & K-5 II 8 01-22-2012 07:35 PM
Random Underexposure With Super A Hamster Film SLRs and Compact Film Cameras 3 02-09-2010 04:46 PM
50mm Underexposure Problem Halco Troubleshooting and Beginner Help 4 09-15-2009 06:32 PM
Weird K10D underexposure problem Kirivon Pentax DSLR Discussion 9 12-19-2008 04:54 AM
problem with underexposure joaosoares5 Pentax DSLR Discussion 7 03-23-2008 08:50 AM
All times are GMT -7. The time now is 06:42 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
